Right block or not #1515529
10/11/13 05:20 PM
10/11/13 05:20 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
Bought a 67 R/T with a running motor and the "original" block. Have driven the car for two seasons and now I decide to see if it is or is not. Car was built in 5/67...block is 12/66..front pad stamped c440hp
I was under the impression, 3 months is the window but some have submitted 6. Any experts out there know ? Thanks in advance...thanks moparts
Re: Right block or not [Re: terzmo] #1515530
10/11/13 05:27 PM
10/11/13 05:27 PM
STL
cdstl Offline
cdstl  Offline
STL
I have a 340 with a block that was cast in January 1971 and went into a 1973 STL car.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Right block or not [Re: terzmo] #1515531
10/11/13 05:42 PM
10/11/13 05:42 PM
AndyF Offline
AndyF  Offline
There is no window for the casting date. There might be a window for engine assembly date but even that would be suspect.
Mopar was horrible at inventory control during the 60's and 70's. Lots of engine blocks sat around for months (years) before being used.
Re: Right block or not [Re: AndyF] #1515532
10/11/13 06:28 PM
10/11/13 06:28 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I can vouch for that. Had a 413 in my 64 300, the 413 was stamped as a 63, then over stamped for 64 and the casting dates were consistent with a 63 as well as the four bolt valve covers, rocker stands, etc. Chrysler used them up that's for sure.
Don't be the exception.
Re: Right block or not [Re: terzmo] #1515533
10/11/13 06:34 PM
10/11/13 06:34 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
That is totally within range to be correct for your car. The key is the stamping date and codes on the ID pad. So far it looks to be correct for your car but you need to post more info.
So far you have posted C440hp
C-1967 Model Year, 440-CID, HP - High Performance
Then should be a date using month and day of month (which typically predates your cars SPD by a short number of days) then there will be a build sequence number (example: 5 would be 5th engine built that shift, etc.).
What is your cars SPD?
