5.9 vs 360 exhaust? #151543
11/16/08 10:18 AM
11/16/08 10:18 AM
Bellville, Mi.
tscuda Offline OP
tscuda  Offline OP
Bellville, Mi.
I'm dropping a 360 in a Jeep CJ5. I need to know if theres a mounting difference between the 360 and 5.9 exhaust at the ports.
Re: 5.9 vs 360 exhaust? [Re: tscuda] #151544
11/16/08 10:35 AM
11/16/08 10:35 AM
same
Re: 5.9 vs 360 exhaust? [Re: RapidRobert] #151545
11/16/08 10:39 AM
11/16/08 10:39 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
same
bolt pattern is the same, but the ports aren't. Magnums don't have exhaust air injection holes and pay very close attention to the manifold to head sealing area some applications get thin and blow exhaust out there.
Don't be the exception.
Re: 5.9 vs 360 exhaust? [Re: Supercuda] #151546
11/16/08 10:49 AM
11/16/08 10:49 AM
Bellville, Mi.
tscuda Offline OP
tscuda  Offline OP
Bellville, Mi.
Ok. So I can buy a set of shorty 5.9 headers instead of hitting a junk yard for 360 manifolds.
Re: 5.9 vs 360 exhaust? [Re: Supercuda] #151547
11/16/08 10:50 AM
11/16/08 10:50 AM
challconv70 Offline
challconv70  Offline
I went the other way, 402 into a small block challenger and had trouble with my headers fitting around my steering. I never was exactly sure why it didn't fit but I think the motor mounts are in a different location on the 2 engines. Take a look at the motor mount locations see if that looks like a problem.
Re: 5.9 vs 360 exhaust? [Re: tscuda] #151548
11/16/08 11:02 AM
11/16/08 11:02 AM
The flange part will & if the rest of the header clears you're looking good.
Re: 5.9 vs 360 exhaust? [Re: RapidRobert] #151549
11/16/08 11:07 AM
11/16/08 11:07 AM
Bellville, Mi.
tscuda Offline OP
tscuda  Offline OP
Bellville, Mi.
Since I have to weld up some engine mounts that would be no big deal. I can put the engine anywhere I need to. Dodge 360 in place of an AMC 258. Ok thanks to all.
