4x4 axle nut torque #1515387
10/11/13 11:43 AM
10/11/13 11:43 AM
The Sunny Shuswap
dodgefarmer Offline OP
The Sunny Shuswap
I' m changing out a front axle on my 95 ram 1500. Does any one have a torque spec for the axle nut and the bearing retainer bolts. BTW this is not a job for any one with a short fuse.
Randy
Re: 4x4 axle nut torque [Re: dodgefarmer] #1515388
10/11/13 12:16 PM
10/11/13 12:16 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
180ft lbs. Do NOT use a 150ft lb torque wrench and think you can just click it a few more times. Broke my torque wrench and almost my nose when my face slammed into the tire.
Re: 4x4 axle nut torque [Re: dodgefarmer] #1515389
10/11/13 12:56 PM
10/11/13 12:56 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Dodgefarmer, what size is that nut? I need to swap out the U-joints on my '01 in the near future, and I'm certain that I don't have the right socket. I guess I'd better be surveying my friends to see which one has a big torque wrench as well...
Re: 4x4 axle nut torque [Re: Fat_Mike] #1515390
10/11/13 01:45 PM
10/11/13 01:45 PM
pennsylvania
poboyengineering Offline
pennsylvania
1 7/16 I think. I have a dedicated one, so I may be wrong..
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: 4x4 axle nut torque [Re: Fat_Mike] #1515391
10/11/13 05:58 PM
10/11/13 05:58 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
My socket is 1 11/16 from napa and I had to grind the outside to fit in the recess where the nut is. Was an 01 1500 4wd
