63-66 a body with v8 what air cleaner to use? #151537
11/16/08 07:46 AM
11/16/08 07:46 AM
Gettysburg Pa
roadrunnerreds Offline OP
Gettysburg Pa
got my 65 dart running and i need to find an air cleaner for it.it has a 360 with a air gap intake and 750 holley carb.was wondering what guys with the same car use for an air cleaner on your car. thanks Brad.
Re: 63-66 a body with v8 what air cleaner to use? [Re: roadrunnerreds] #151538
11/16/08 08:49 AM
11/16/08 08:49 AM
Owego, NY
JBurch Offline
JBurch  Offline
Owego, NY
I used an Edelbrock with a drop base on my 65 Barracuda, 318 with a Torquer II intake, 750 DP Holley
Re: 63-66 a body with v8 what air cleaner to use? [Re: roadrunnerreds] #151539
11/16/08 11:04 AM
11/16/08 11:04 AM
O/T Brad what headers are you using. any problems
Re: 63-66 a body with v8 what air cleaner to use? [Re: RapidRobert] #151540
11/17/08 10:38 AM
11/17/08 10:38 AM
Gettysburg Pa
Gettysburg Pa
they are tti headers and they are a pita but are really nice headers.my inner fender wells were so nice that i did not want to cut them for fender well headers.the one problem or may be my mistake was i bought that starter they said you had to buy to work with these headers and it did not fit i used a regular mini starter other than that they are just time consuming to install. Brad
Re: 63-66 a body with v8 what air cleaner to use? [Re: roadrunnerreds] #151541
11/17/08 11:23 AM
11/17/08 11:23 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
before I cut my hood I had a drop base K&N that worked on a M1 Mopar dual plane intake...
Re: 63-66 a body with v8 what air cleaner to use? [Re: DJVCuda] #151542
11/17/08 01:17 PM
11/17/08 01:17 PM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
I used this drop base from Summit to put an RB, with an RPM manifold, in my 68 Dart. Saved me from cutting my hood.
http://store.summitracing.com/partdetail...mp;autoview=sku
codfish
