tach in rally dash problem #1515338
10/11/13 10:57 AM
10/11/13 10:57 AM
NE Ohio
66HP2 Offline OP
66HP2  Offline OP
NE Ohio
My tach pegs when I turn on the ignition. any ideas?
Re: tach in rally dash problem [Re: 66HP2] #1515339
10/16/13 10:57 AM
10/16/13 10:57 AM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
What is this in?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: tach in rally dash problem [Re: Magnumguy] #1515340
10/16/13 11:36 AM
10/16/13 11:36 AM
Fresno, CA
Jim_Lusk Online content
Jim_Lusk  Online Content
Fresno, CA
Not enough info, but if this is a fresh install I would suggest that you have it wired wrong. If it has worked in the past without you making any changes the tach probably needs repair (I'd start with a new circuit board).
