Stock shroud for 26" 3 row Champion radiators? #1515286
10/11/13 02:33 AM
10/11/13 02:33 AM
Tacoma, Washington USA
Adam71Charger Offline OP
Do stock shrouds work with champion radiators? They advertise that their CC375 3row 26" radiator fits OEM mounts, but can a stock 26" fan shroud work with that radiator? I wanted this radiator for my 500hp big block Im putting in my 71 b body. I can afford it, and it says it cools up to 600hp. I would like to use a clutch fan and shroud. But Im not finding anything that indicates a stock shroud will fit.
But for $100 more, they also offer 2 12" electric fans with an aluminum shroud.
Re: Stock shroud for 26" 3 row Champion radiators? [Re: Adam71Charger] #1515287
10/11/13 09:43 AM
10/11/13 09:43 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
If it fits the stock location there is nothing stopping you from making it fit , is there ?
Are you asking if they are setup so a factory shroud can be bolted directly on ???
Re: Stock shroud for 26" 3 row Champion radiators? [Re: JohnRR] #1515288
10/11/13 12:58 PM
10/11/13 12:58 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
And if that's the question the answer is yes...I bought the 26 inch B body unit.. it has provisions for it and a shroud will bolt up...Here's the rad with a shroud on it {2nd car in}.. LINK
Re: Stock shroud for 26" 3 row Champion radiators? [Re: screamindriver] #1515289
10/11/13 01:28 PM
10/11/13 01:28 PM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
I was thinking of a Champion radiator for my 340 Duster (22" I think). Will the stock shroud fit it too?
Re: Stock shroud for 26" 3 row Champion radiators? [Re: bigblock340power] #1515290
10/11/13 01:37 PM
10/11/13 01:37 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Below is a pic of the 22" I put in the Dart. It looks correct for the factory shroud but I can't swear to it.
...FAFO...
Re: Stock shroud for 26" 3 row Champion radiators? [Re: JohnRR] #1515291
10/11/13 02:57 PM
10/11/13 02:57 PM
Yes im asking if a factory shroud will bolt on.
Re: Stock shroud for 26" 3 row Champion radiators? [Re: Adam71Charger] #1515292
10/11/13 03:00 PM
10/11/13 03:00 PM
Kentucky
dfsmopars Offline
dfsmopars  Offline
Kentucky
Attempted to install a Champion in my '72 b-body which is a 26" opening. Could have modified the radiator a little to fit the support but there was NO way the shroud was going to fit. Champion took it back but offered no alternative.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: Stock shroud for 26" 3 row Champion radiators? [Re: dfsmopars] #1515293
10/11/13 03:15 PM
10/11/13 03:15 PM
KS
MoparKansas Offline
MoparKansas  Offline
KS
The shroud should work if you modify the holes on either the shroud or the aluminum rails of the radiator (at least on the 26" one on my Challenger). You will have to get some of those sheet metal screw inserts clips or use your old ones though. Mine isn't on yet, but I got it really close one day and quit after about the third time since the car didn't overheat without the shroud I left it off. The fan clutch went out this summer and the replacement doesn't cool in traffic well, so I am going to put it on over the winter - with a few mods it should work.
I also had to do some grinding to get the radiator to the right spot. No big deal though. Cheaper than a recore of the stock unit.
Re: Stock shroud for 26" 3 row Champion radiators? [Re: MoparKansas] #1515294
10/11/13 04:18 PM
10/11/13 04:18 PM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
My 26 inch B Body unit lines up to the core support great but I haven't held the shroud up to it to see if the bolts align. Will be doing that soon. I plan to ditch the shroud and fan/clutch and go with the Mercedes C class electric unit at some point.
I’m listening.
Re: Stock shroud for 26" 3 row Champion radiators? [Re: MoparKansas] #1515295
10/11/13 04:21 PM
10/11/13 04:21 PM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
I say Ma Mopar knew what they were doing when they designed this.
If it aint broke, dont fix it!
Besides, electric fans are great for racing but seem to have issues on the street. Noisey, electrical drain on the system, burning out on the way to "Cruise Night" not to mention your amps gauge etc..... "Thermostatic" fan clutches use next to no HP when not needed too.
more of , so I guess thats my four cents worth. Still wont buy a cup of coffee
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: Stock shroud for 26" 3 row Champion radiators? [Re: Copper Dart] #1515296
10/11/13 07:10 PM
10/11/13 07:10 PM
Thanks for the aphorism, but there is no radiator or fan to begin with.
Re: Stock shroud for 26" 3 row Champion radiators? [Re: dfsmopars] #1515297
10/11/13 07:34 PM
10/11/13 07:34 PM
Did you get the 2 row, 3 row or 4 row radiator? Was it their line that is specifically for b bodies?
Re: Stock shroud for 26" 3 row Champion radiators? [Re: Adam71Charger] #1515298
10/11/13 08:15 PM
10/11/13 08:15 PM
Andrews,In. U.S.of A.
67_Satellite Offline
Mine fit but there was a small gap around the perimeter.I cut foam pipe insulation into quarters and sealed it up.It's not even noticeable unless you look for it.
Re: Stock shroud for 26" 3 row Champion radiators? [Re: Adam71Charger] #1515299
10/14/13 03:28 PM
10/14/13 03:28 PM
Kentucky
dfsmopars Offline
dfsmopars  Offline
Kentucky
It was a Champion specific radiator, 3 core. The frame was so far off from fitting the shroud I really believed they had shipped the wrong one. When I contacted the guy (forgotten his name) he did not try to investigate it he just said send it back, in which I did. I still need a radiator.
Re: Stock shroud for 26" 3 row Champion radiators? [Re: Copper Dart] #1515300
10/16/13 04:11 PM
10/16/13 04:11 PM
Texas
jrust Offline
jrust  Offline
Texas
Hey Copper Dart what kind of shroud is that? I have a 26" aluminum radiator and I sure like the looks of that shroud.
Re: Stock shroud for 26" 3 row Champion radiators? [Re: jrust] #1515301
10/18/13 10:15 AM
10/18/13 10:15 AM
NORTHERN CA
HUSTLESTUFF Offline
HUSTLESTUFF  Offline
NORTHERN CA
If you have a 500 inch motor, I would highly reccomend a Wizard Cooling radiator. It will use a stock shroud. I would not use electric fans. I had dual Spals that could not keep my 512 cool. I would use the Wizard, stock shroud, Jag clutch fan and five blade fan. I just changed to this and am so happy I did. Have heard some not so good stuff on champion. Wizard quality is what I think we are all after. BTW I did 1.25 tubes. Do it once!! Mike
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL
RIP UN
Re: Stock shroud for 26" 3 row Champion radiators? [Re: Adam71Charger] #1515302
10/18/13 10:24 AM
10/18/13 10:24 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
GlenRay not only has the correct repo radiator, but the shroud bolts right up , no fuss, no muss.
Re: Stock shroud for 26" 3 row Champion radiators? [Re: bigblock340power] #1515303
10/18/13 10:54 AM
10/18/13 10:54 AM
michigan
bksgonzo Offline
bksgonzo  Offline
michigan
Just got a 22-2 row from champion for my 71demon. I had to modify the passanger side mounting bracket on the lower slot had to raise the slot another inch to make sit level and the shroud holes are to low had to drill 4 new holes higher up.
