Re: Stock shroud for 26" 3 row Champion radiators?
[Re: JohnRR]
#1515288
10/11/13 12:58 PM
10/11/13 12:58 PM
Posts: 7,195 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
If it fits the stock location there is nothing stopping you from making it fit , is there ?
Are you asking if they are setup so a factory shroud can be bolted directly on ???
And if that's the question the answer is yes...I bought the 26 inch B body unit.. it has provisions for it and a shroud will bolt up...Here's the rad with a shroud on it {2nd car in}.. LINK
[Re: bigblock340power]
#1515290
10/11/13 01:37 PM
10/11/13 01:37 PM
Posts: 5,102 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
Below is a pic of the 22" I put in the Dart. It looks correct for the factory shroud but I can't swear to it.
...FAFO...
[Re: JohnRR]
#1515291
10/11/13 02:57 PM
10/11/13 02:57 PM
Posts: 1,521 Tacoma, Washington USA
Adam71Charger
Yes im asking if a factory shroud will bolt on.
[Re: Adam71Charger]
#1515292
10/11/13 03:00 PM
10/11/13 03:00 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
Attempted to install a Champion in my '72 b-body which is a 26" opening. Could have modified the radiator a little to fit the support but there was NO way the shroud was going to fit. Champion took it back but offered no alternative.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
[Re: MoparKansas]
#1515295
10/11/13 04:21 PM
10/11/13 04:21 PM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
I say Ma Mopar knew what they were doing when they designed this. If it aint broke, dont fix it! Besides, electric fans are great for racing but seem to have issues on the street. Noisey, electrical drain on the system, burning out on the way to "Cruise Night" not to mention your amps gauge etc..... "Thermostatic" fan clutches use next to no HP when not needed too. more of , so I guess thats my four cents worth. Still wont buy a cup of coffee
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
[Re: Copper Dart]
#1515296
10/11/13 07:10 PM
10/11/13 07:10 PM
Adam71Charger
Thanks for the aphorism, but there is no radiator or fan to begin with.
[Re: dfsmopars]
#1515297
10/11/13 07:34 PM
10/11/13 07:34 PM
Adam71Charger
Did you get the 2 row, 3 row or 4 row radiator? Was it their line that is specifically for b bodies?
[Re: Adam71Charger]
#1515299
10/14/13 03:28 PM
10/14/13 03:28 PM
dfsmopars
Kentucky
It was a Champion specific radiator, 3 core. The frame was so far off from fitting the shroud I really believed they had shipped the wrong one. When I contacted the guy (forgotten his name) he did not try to investigate it he just said send it back, in which I did. I still need a radiator.
[Re: jrust]
#1515301
10/18/13 10:15 AM
10/18/13 10:15 AM
Posts: 1,376 NORTHERN CA
HUSTLESTUFF
NORTHERN CA
If you have a 500 inch motor, I would highly reccomend a Wizard Cooling radiator. It will use a stock shroud. I would not use electric fans. I had dual Spals that could not keep my 512 cool. I would use the Wizard, stock shroud, Jag clutch fan and five blade fan. I just changed to this and am so happy I did. Have heard some not so good stuff on champion. Wizard quality is what I think we are all after. BTW I did 1.25 tubes. Do it once!! Mike
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL RIP UN
