77 Jeep J10 PU #1515031
10/10/13 07:09 PM
10/10/13 07:09 PM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
Anyone on here own one?
Re: 77 Jeep J10 PU [Re: dart4forte] #1515032
10/10/13 08:08 PM
10/10/13 08:08 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Re: 77 Jeep J10 PU [Re: dart4forte] #1515033
10/10/13 08:49 PM
10/10/13 08:49 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
There is a Jeep Gladiator pickup sitting in a driveway a half mile from my house. Looks like it is being used to collect yard trash and then driven to the dump when full. What do you want to know?
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: 77 Jeep J10 PU [Re: Polarapete] #1515034
10/10/13 09:00 PM
10/10/13 09:00 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I would gladly adopt the rear axle out of 1..
I am truckless..
Re: 77 Jeep J10 PU [Re: redraptor] #1515035
10/11/13 02:49 AM
10/11/13 02:49 AM
Mesa, Arizona
Mesa, Arizona
I have a parking light lens if someone needs one. Leftover from my 1977 J10. Died in a collision in 2001.
Re: 77 Jeep J10 PU [Re: 340SHORTY] #1515036
10/11/13 03:47 PM
10/11/13 03:47 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I have a Dana 60-2 that I have had narrowed to fit my '87 D100. It came out of a '69 to '73 Jeep Gladiator. I have all the parts (new seals, 1310 companion flange and a shortend and re-splined Driver side axle) I just have to put it all together. But before I do all that, I need to find a good 518 to build to compensate for the 3.21 to 4.10 axle change. So the process is trans first, mount it, remove the 8.25 rear, mount the Dana, position it on new spring pads matching the original pinion angle, tack the pads in place, remove the Dana, finish weld the pads, assemble the rear end and install it and finally shorten the drive shaft to match. Of course, my wife is asking why do I want to do this when the truck runs so well as it is?? I don't really have a good answer for that! And I know you don't either, Larry. BTW I am too busy to take pictures for "show & tell"!
2008 Honda Element
