Ever see a 440-1 head like this? #1514515
10/09/13 03:43 PM
10/09/13 03:43 PM
Minnesota
Barnstorm Offline OP
Minnesota
Car slowed at half track and subsequent autopsy revealed #3 and 5 combustion chambers BURNED thru the aluminum and the 5319 Fel-Pro gasket. No other damage. 500in 14-1comp 36deg timing C14 fuel. No signs of corrosion. ??? [tboomer meltdown?]
The little old lady from Pasadena is back!
Re: Ever see a 440-1 head like this? [Re: Barnstorm] #1514516
10/09/13 03:47 PM
10/09/13 03:47 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
is it warped? aluminum heads are very delicate. If it warped, that damage could follow very soon after
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: Ever see a 440-1 head like this? [Re: Barnstorm] #1514517
10/09/13 03:48 PM
10/09/13 03:48 PM
Cab_Burge Online work
Cab_Burge  Online Work
I've expereinced that with a iron set of Max wedge heads with the Fel Pro composition head gaskets, it took the block out also
Re: Ever see a 440-1 head like this? [Re: Cab_Burge] #1514518
10/09/13 04:42 PM
10/09/13 04:42 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
14-1 you may want to run Cometics after you get her repaired.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Ever see a 440-1 head like this? [Re: Barnstorm] #1514519
10/09/13 04:57 PM
10/09/13 04:57 PM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
Head gasket failure, weld up the head, use Cometics.
1967 Coronet, 1989 Daytona tube chassis. Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT. -Banned for life from V8Buick.com-
Re: Ever see a 440-1 head like this? [Re: d7cook] #1514520
10/09/13 06:38 PM
10/09/13 06:38 PM
Minnesota
Minnesota
That's what the consensus seems to be...also blew out #7 header gasket on the same pass. What a combined weird sound. Thanx guys.
Re: Ever see a 440-1 head like this? [Re: Barnstorm] #1514521
10/09/13 06:54 PM
10/09/13 06:54 PM
Delray beach, Florida
P
Performance Only Offline
P
It's the hottest part of the head, the wrong head gasket and possibly just a degree or two of too much timing.
machine shop owner and engine builder
Re: Ever see a 440-1 head like this? [Re: Performance Only] #1514522
10/09/13 09:41 PM
10/09/13 09:41 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've seen it more than once on iron big blocks. Nearly every time, to much timing. Why are you running 36 on a -1, I run 32? Mine slowed down .5 mph at 34. 28 only slowed the car .05. I've never tried 30.
Doug
Re: Ever see a 440-1 head like this? [Re: dvw] #1514523
10/09/13 10:19 PM
10/09/13 10:19 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
If you look at the fire ring on the head it is off center. The chamber on the right has very little material covering the steel ring in the gasket. Put the head on the bare block and be sure the chambers are centered over the bore. Either the block is off, the dowl holes in the head or the gasket are not drilled properly. I had one gasket deteriorate, but not burn through about 5 years ago on a particular block (found it on inspection).
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: Ever see a 440-1 head like this? [Re: dvw] #1514524
10/09/13 10:23 PM
10/09/13 10:23 PM
Minnesota
Minnesota
This is a 10yr old well sorted out combo {Lynn Balek]. We don't thing timing was a factor. NO signs of detonation. Just stuff happens.
Re: Ever see a 440-1 head like this? [Re: Barnstorm] #1514525
10/10/13 07:55 AM
10/10/13 07:55 AM
tboomer Offline
tboomer  Offline
Sorry to see that Billy... Is Balek going to fix her up? The track was biting pretty good and my suspension also took a beating that day. See ya next year!!
Re: Ever see a 440-1 head like this? [Re: Barnstorm] #1514526
10/10/13 08:03 AM
10/10/13 08:03 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I used copper head gaskets and wire and receiver grooves for a combo like that.
Re: Ever see a 440-1 head like this? [Re: Barnstorm] #1514527
10/10/13 11:19 AM
10/10/13 11:19 AM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
When they weld up the head it'll get milled as well. Plan on taking in the other head to have it milled to match. Also I've ran Cometic head gaskets on old blocks with a rough cut deck even though cometics call for a smooth surface so you may or may not want to deck the block.
Re: Ever see a 440-1 head like this? [Re: Barnstorm] #1514528
10/10/13 02:10 PM
10/10/13 02:10 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
5319 Fel-Pro gasket
i'm not familiar with that number, anyone else?
Re: Ever see a 440-1 head like this? [Re: jamesc] #1514529
10/10/13 02:34 PM
10/10/13 02:34 PM
PA.
"Little"John
"Little"John
PA.
5319 Fel-Pro gasket
I googled that number and nothing came up up.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Ever see a 440-1 head like this? [Re: pittsburghracer] #1514530
10/10/13 03:04 PM
10/10/13 03:04 PM
in the middle
dodger mope Offline
dodger mope  Offline
in the middle
it might be interesting to see the head gasket on the other side. might be a clue if the gasket died a slow death because of a hair too much timing?
Re: Ever see a 440-1 head like this? [Re: dodger mope] #1514531
10/10/13 03:36 PM
10/10/13 03:36 PM
AndyF Offline
AndyF  Offline
I usually run 35 degrees with the Indy head so 36 should work.
Might be a topic for a different thread but maybe everyone with Indy heads should compare ignition timing. Might be interesting to see what different people are running.
Re: Ever see a 440-1 head like this? [Re: jamesc] #1514532
10/10/13 03:42 PM
10/10/13 03:42 PM
AndyF Offline
AndyF  Offline
5319 Fel-Pro gasket
No such Fel Pro number so it is a typo. Only Fel Pro gasket that would be good at 14:1 is the 1105. The 1105 is for big bore engines and it is 0.051 thick so it requires a special setup. Cometic is probably the way to go on this engine.
Re: Ever see a 440-1 head like this? [Re: AndyF] #1514533
10/10/13 04:16 PM
10/10/13 04:16 PM
Minnesota
Minnesota
My bad...Fel-Pro 8519 PT1
Re: Ever see a 440-1 head like this? [Re: Barnstorm] #1514534
10/10/13 05:05 PM
10/10/13 05:05 PM
Saskatchewan, Canada
cudabin Offline
cudabin  Offline
I know every combo is different, but I made best power at 34 degrees with my CNC345cc -1 Heads on the dyno...
Runs OK there for me and less stress on the bearings etc IMO.
Good luck with it!
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
