Ever see a 440-1 head like this?
#1514515
10/09/13 03:43 PM
10/09/13 03:43 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
Car slowed at half track and subsequent autopsy revealed #3 and 5 combustion chambers BURNED thru the aluminum and the 5319 Fel-Pro gasket. No other damage. 500in 14-1comp 36deg timing C14 fuel. No signs of corrosion. ??? [tboomer meltdown?]
The little old lady from Pasadena is back!
Re: Ever see a 440-1 head like this?
[Re: Barnstorm]
#1514516
10/09/13 03:47 PM
10/09/13 03:47 PM
Posts: 1,106 Northeast
VincentVega
Northeast
is it warped? aluminum heads are very delicate. If it warped, that damage could follow very soon after
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
[Re: Cab_Burge]
#1514518
10/09/13 04:42 PM
10/09/13 04:42 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
14-1 you may want to run Cometics after you get her repaired.
[Re: Barnstorm]
#1514519
10/09/13 04:57 PM
10/09/13 04:57 PM
Posts: 290 Cincinnati, Ohio
d7cook
Cincinnati, Ohio
Head gasket failure, weld up the head, use Cometics.
1967 Coronet, 1989 Daytona tube chassis.
Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT.
-Banned for life from V8Buick.com-
[Re: dvw]
#1514524
10/09/13 10:23 PM
10/09/13 10:23 PM
Barnstorm
Minnesota
This is a 10yr old well sorted out combo {Lynn Balek]. We don't thing timing was a factor. NO signs of detonation. Just stuff happens.
[Re: Barnstorm]
#1514526
10/10/13 08:03 AM
10/10/13 08:03 AM
Challenger 1
Cincinnati, Ohio
I used copper head gaskets and wire and receiver grooves for a combo like that.
[Re: jamesc]
#1514532
10/10/13 03:42 PM
10/10/13 03:42 PM
Posts: 31,036 Oregon
AndyF
5319 Fel-Pro gasket
i'm not familiar with that number, anyone else?
No such Fel Pro number so it is a typo. Only Fel Pro gasket that would be good at 14:1 is the 1105. The 1105 is for big bore engines and it is 0.051 thick so it requires a special setup. Cometic is probably the way to go on this engine.
[Re: AndyF]
#1514533
10/10/13 04:16 PM
10/10/13 04:16 PM
Barnstorm
Minnesota
My bad...Fel-Pro 8519 PT1
[Re: Barnstorm]
#1514534
10/10/13 05:05 PM
10/10/13 05:05 PM
Posts: 903 Saskatchewan, Canada
cudabin
I know every combo is different, but I made best power at 34 degrees with my CNC345cc -1 Heads on the dyno...
Runs OK there for me and less stress on the bearings etc IMO.
Good luck with it!
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
