Reproduction Radiators #151444
11/15/08 08:15 PM
11/15/08 08:15 PM
Sonoran desert, Arizona, USA
moparjo68 Offline OP
Where is a good sorce to purchase a reproduction
radiator for my 68 Charger? I have checked prices at Year One and they want a small forture for theirs. Can you recommend any other sites to check.
Thanks Joe
Re: Reproduction Radiators [Re: moparjo68] #151445
11/15/08 09:02 PM
11/15/08 09:02 PM
N.W. INDIANA
moparjohn Offline
moparjohn  Offline
N.W. INDIANA
Try GLENRAY radiators. They display at most major shows and are out of Wisconsin I believe.
Re: Reproduction Radiators [Re: moparjohn] #151446
11/15/08 09:32 PM
11/15/08 09:32 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
if you think YO is expensive Glen RAy will be even more.
Re: Reproduction Radiators [Re: moparjo68] #151447
11/15/08 09:33 PM
11/15/08 09:33 PM
central new york
pettyblue440 Offline
central new york
Unless your charger is a hemi you should be able to buy an original and have it restored for far less than a reproduction.
Re: Reproduction Radiators [Re: pettyblue440] #151448
11/15/08 10:19 PM
11/15/08 10:19 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Say what you will about Glen-Rays prices, there is NOTHING on the market even remotely similar to an original other than thiers. That's why I'm a dealer for them, I only carry the best.
Re: Reproduction Radiators [Re: moparjo68] #151449
11/15/08 10:22 PM
11/15/08 10:22 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Buy directly from US Radiators, they have standard core, and upgraded micro tube radiators, that look original,(no part #'s) and bolt in,.....only issuse I have with them is the clocking of the cap neck tangs,( the cap will lock at 10 and 4, instead of 9 and 3, in regard to the cap ears).......priced about $250-$500 depending on how, what,you need
Glen-Ray offerers a very nice, correct, complete radiator, if it's in your budget, $500-$1000 recommended if your a "numbers" kinda guy
Re: Reproduction Radiators [Re: moparjo68] #151450
11/16/08 01:43 PM
11/16/08 01:43 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Thanks Joe
Just to cover the bases...
Do you have a radiator right now for the car? A local radiator shop will put in a new core using your old end tanks and side brackets.
Re: Reproduction Radiators [Re: DAYCLONA] #151451
11/16/08 03:04 PM
11/16/08 03:04 PM
Missouri
MOBodyman Offline
MOBodyman  Offline
Missouri
I purchased one from US Radiator for my '68 Barracuda and wasn't too happy with it. In addition to the cap being clocked wrong, the overflow nipple was on the wrong side and there were no tabs to hold the overflow hose like the original radiator. I had to ream the mounting holes to bolt it up. It looked like I had soldered it together,(not good). The edge of the top tank was bent a little when they installed it so they just filled the gap with solder.
I went ahead and used it as I was wanting to drive the car immediately but looking back I should have returned it. It was functional but no where near 'right'.
Dallas
2012 Rallye Redline Challenger, 1st new car!
2010 Ram 1500 4wd HEMI-hauler
2014 Dodge Dart-gas saver
4 projects and a bunch of parts cars, losing interest since buying the Challenger lol
1969 Dodge Coronet 500-'gonna fix 'er up someday!'
Re: Reproduction Radiators [Re: MOBodyman] #151452
11/16/08 04:36 PM
11/16/08 04:36 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
Have Glen Ray re-build yours with a modern core and keep it orig looking. Did mine for $500 and it is better than orig in looks and function. The US Radiator will not keep the stock look and value to your car.
Re: Reproduction Radiators [Re: autoxcuda] #151453
11/16/08 08:41 PM
11/16/08 08:41 PM
No sorry to say I do not have my original radiator, or any radiator for this car. That's why i'm open to all responses where this project is concerned...Thanks to all
Re: Reproduction Radiators [Re: moparjo68] #151454
11/16/08 09:46 PM
11/16/08 09:46 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
What radiator do you need?
Big-block vs. small block??
22" vs. 26"??
Re: Reproduction Radiators [Re: 6bblgt] #151455
11/16/08 11:57 PM
11/16/08 11:57 PM
Car came off the assembly line with a 318, but have replaced it with a 383, the big block. How do I know if I need the 22 or 26 inch?
