Barracuda wipers stopped working #1514386
10/09/13 09:56 AM
10/09/13 09:56 AM
Farther south than I was befor...
ChrisH Offline OP
ChrisH  Offline OP
The wife's 68 Barracuda's wipers just stopped working. I replaced the switch with one I think is good. It was on my parts shelf so who knows if it is good. How do I trouble shoot this? If wifey ain't happy no one is!
Re: Barracuda wipers stopped working [Re: ChrisH] #1514387
10/09/13 10:17 AM
10/09/13 10:17 AM
Stroudsburg, PA
Erik Offline
Erik  Offline
Stroudsburg, PA
This may be a stupid question.......Did you check the ground at the motor?
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: Barracuda wipers stopped working [Re: Erik] #1514388
10/09/13 05:25 PM
10/09/13 05:25 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
Or the switch ?
NS1AAR
Re: Barracuda wipers stopped working [Re: ns1aar] #1514389
10/09/13 06:51 PM
10/09/13 06:51 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
There was a Technical Service Bulletin and a parts counter fixer upper kit.
The parts went inside the motor housing and maybe had something to do with the reverse/park circuit and mechanicals.
Sorry, can't remember if this TSB and kit was for a parking problem or a non-operating problem. I installed the kit in my Barracuda in the early 70s.
If you need a 68 FSM/wiring schematic, PM me. You could jumper 12v directly to the motor without the switch, guided by the schematics. This would tell you if the motor works by itself skipping the switch. The schematic shows 4 wires for both variable speed and 2-speed wipers, brown, red, dark green, and dark blue in the engine compartment, but you will have to correlate this to the instrument panel schematic and switch to see which wire(s) you need to jumper.
Re: Barracuda wipers stopped working [Re: ChrisH] #1514390
10/09/13 08:47 PM
10/09/13 08:47 PM
Slidell, La.
doctor_mopar Offline
Slidell, La.
If you havn't tested anything.......... hit the motor a couple times with a hammer. Works quite often !
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: Barracuda wipers stopped working [Re: Erik] #1514391
10/09/13 11:17 PM
10/09/13 11:17 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Re: Barracuda wipers stopped working [Re: TJP] #1514392
10/10/13 08:34 AM
10/10/13 08:34 AM
ChrisH Offline OP
ChrisH  Offline OP
Thanks for all the answers. I will let you know how it turns out when I get to it next week.
Re: Barracuda wipers stopped working [Re: ChrisH] #1514393
10/13/13 02:52 AM
10/13/13 02:52 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
The TSBs are worth a read and may help. See:
http://www.hamtramck-historical.com/library.shtml
and scroll to bottom. Read "Understanding and Using..." first.
The Plymouth TSB for 1970 in Chapter 8 Electrical has testing procedures for wipers, as does, of course, the FSM. There are other wiper TSBs for other years, including 69.
