Re: Barracuda wipers stopped working
[Re: ChrisH]
#1514387
10/09/13 10:17 AM
10/09/13 10:17 AM
Posts: 3,288 Stroudsburg, PA
Erik
Stroudsburg, PA
This may be a stupid question.......Did you check the ground at the motor?
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
[Re: ns1aar]
#1514389
10/09/13 06:51 PM
10/09/13 06:51 PM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
There was a Technical Service Bulletin and a parts counter fixer upper kit.
The parts went inside the motor housing and maybe had something to do with the reverse/park circuit and mechanicals.
Sorry, can't remember if this TSB and kit was for a parking problem or a non-operating problem. I installed the kit in my Barracuda in the early 70s.
If you need a 68 FSM/wiring schematic, PM me. You could jumper 12v directly to the motor without the switch, guided by the schematics. This would tell you if the motor works by itself skipping the switch. The schematic shows 4 wires for both variable speed and 2-speed wipers, brown, red, dark green, and dark blue in the engine compartment, but you will have to correlate this to the instrument panel schematic and switch to see which wire(s) you need to jumper.
[Re: Erik]
#1514391
10/09/13 11:17 PM
10/09/13 11:17 PM
Posts: 15,498 Omaha Ne
TJP
Omaha Ne
![](/ubbthreads/images/graemlins/iagree.gif)
[Re: ChrisH]
#1514393
10/13/13 02:52 AM
10/13/13 02:52 AM
kentj340
Cut and Shoot, TX
The TSBs are worth a read and may help. See: http://www.hamtramck-historical.com/library.shtmland scroll to bottom. Read "Understanding and Using..." first. The Plymouth TSB for 1970 in Chapter 8 Electrical has testing procedures for wipers, as does, of course, the FSM. There are other wiper TSBs for other years, including 69.
