I ran this lunati roller cam in a 318 with 360 heads and then in a 318 with #302 heads. worked very good in a 85 truck. stock smooth idle,18-19 mpg/hwy
used all stock valve gear and roller lifters with comp 901-16 springs.
258/264
207/213 @.050
.458/.485 lift
108/110 ICL/LSA
went to the hughes whiplash roller cam for a 318 and is almost exact same specs but with a much tighter LSA for a choppy idle
208/213 @ .050
102/107 ICL/LSA
.480/.487 lift
just like it said, idles like a funny car and smooths right out with lots of lowend torque right off idle. light throttle drives like stock/heavy throttle torques right up and pull hard to 5500 rpm.
I have 2 whiplash 318 roller cams now and 1 flat tappet whiplash for my 440 truck going in.
