74 Scamp with a 70-72 front Grill #1513979
10/08/13 12:09 PM
10/08/13 12:09 PM
South Carolina
K
KRYPTONITE Offline OP
K
South Carolina
I have a 74 Scamp and was wanting to know how hard is it to put the 70-72 front grill in instead of the 74?? I know the hood will be different but plan to buy a Fiberglass one anyways!!
Does the Grill just bolt on... are they same??
Re: 74 Scamp with a 70-72 front Grill [Re: KRYPTONITE] #1513980
10/08/13 12:14 PM
10/08/13 12:14 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Fenders are also different.
Re: 74 Scamp with a 70-72 front Grill [Re: 62maxwgn] #1513981
10/08/13 12:15 PM
10/08/13 12:15 PM
South Carolina
K
K
South Carolina
wow, ok I didn't know that, I thought they were the same!!
Re: 74 Scamp with a 70-72 front Grill [Re: KRYPTONITE] #1513982
10/08/13 01:20 PM
10/08/13 01:20 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
you have the header panel that goes across the front on a 74 , not so on a 72 , you would basically have to swap the whole 72 nose over to the 74 including the front bumper which you'll need to add the mount points for the 72 I am pretty sure as the bumpers mount differently.
Re: 74 Scamp with a 70-72 front Grill [Re: JohnRR] #1513983
10/08/13 11:43 PM
10/08/13 11:43 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The fenders are identical EXCEPT for the two tabs that support the steel panel that the grille attaches to. I took a 70-72 steel panel and extended the edges about 3/4" per side, then used a self tapping screw ro attach it to the underside of the fender on each side.
The 1974 model was a changeover year for bumper mounting degign. Early 1974 models had a traditional style bumper mount design. Then about mid year, the shock absorber design was integrated. My 74 FrankenDuster had the later design. To mimic the 70-72 design, I made a "nut-plate" and slid it inside the frame rail, then welded it in place. Now the bumper could be mounted like an earlier car.
Re: 74 Scamp with a 70-72 front Grill [Re: Kern Dog] #1513984
10/09/13 11:05 AM
10/09/13 11:05 AM
Midwestern Indiana
duster2 Offline
duster2  Offline
Midwestern Indiana
73 Duster , 70 fenders, 68 Valiant hood and grill.
