383 Freeze Plugs #1513688
10/07/13 08:25 PM
10/07/13 08:25 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Had some leaking freeze plugs on this motor. its a 71 383. I got the easy ones out already but I have to jack up the motor and remove the engine mount to get to the other ones. These plugs measure out at 1 41/64. Is this correct? What ideas are out there to get the crap out of the block before I put the new ones in?
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: 383 Freeze Plugs [Re: 19cuda73] #1513689
10/07/13 09:34 PM
10/07/13 09:34 PM
garden hose with a spray nozzle. Best would be to have one open on each side & as many open as possible
Re: 383 Freeze Plugs [Re: RapidRobert] #1513690
10/07/13 10:19 PM
10/07/13 10:19 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
1 5/8 is the typical size. I like the deep cup rather than the shallow ones. If you have side plugs leaking the rear will not be far behind. Need to pull the engine or drop the transmission for these.
Re: 383 Freeze Plugs [Re: MoparforLife] #1513691
10/07/13 10:59 PM
10/07/13 10:59 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
I think I got most of it out with a piece of h/d wire and a strong shop vac. Its currently dry inside, I drained out the water about a month ago. May still use the water hose idea as well. This is a big block no plugs on the back side right?
1972 Corvette
Re: 383 Freeze Plugs [Re: 19cuda73] #1513692
10/07/13 11:42 PM
10/07/13 11:42 PM
Correct
