Re: REBUILT 440 ENGINE overheats - HELP.
[Re: JohnRR]
#1513427
10/08/13 10:55 AM
10/08/13 10:55 AM
Posts: 2,091 Delray beach, Florida
Performance Only
Does the lower hose have a spring in it to keep it from collapsing? It might not collapse without a stat in it but it will when the coolant gets pressurized against the stat. By the way, just in case, the spring on the thermostat gets installed down. Make sure it's not backwards.
machine shop owner and engine builder
[Re: JohnRR]
#1513428
10/08/13 11:00 AM
10/08/13 11:00 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Since it runs at 170, why not let the next guy deal with it? It is a flip afterall.
But,the next guy will post the same thing and we'll have to start all over again !! ![](/ubbthreads/images/graemlins/whistling.gif)
[Re: minnesota guy]
#1513436
10/09/13 06:50 PM
10/09/13 06:50 PM
Posts: 683 Northern NJ
68 Sat
Northern NJ
I had the exact same problem and spent a small fortune trying to fix it. At the end of the day it was the MP non adjustable advance in the distributor (sp?) that was causing my issue. I changed to a Mallory unit and solved my overheating problem instantly. The way it was explained to me was if the advance is not adjusted properly it will cause the engine to run hot. My explanantion is elementary but I hope you get the jist...good luck.
1963 Chrysler 300 Pace Setter Convertible 21K mile survivor
1969 Dodge Coronet 500
1956 Desoto Hemi
1955 Chrysler C300
[Re: feets]
#1513437
10/09/13 07:09 PM
10/09/13 07:09 PM
Challenger 1
Cincinnati, Ohio
Facts: Both pumps/impellers turn clockwise -
Both impellers are faced the same. Neither is backwards. The blades themselves are curved the same way.
Do ya think installing the left pump non ac will make any difference?
No. You are moving water.
I'd stick the first pump back on and follow the advice I posted on the other thread. You could have saved the time and trouble of pulling the pump.
Get an IR temp gun. Start looking for odd heat patterns.
Read that post I linked earlier. There are no secrets in overheating issues.You can probably diagnose that thing in less than 10 minutes with a temp gun.
Not if it's a tuning problem which I'm betting it is just as long as he has a spring in the lower hose.
Another thing I would ask the OP is, did you purge the system of air?
Did you drive the car or it just idling in the driveway when it overheated?
[Re: 68 Sat]
#1513438
10/09/13 07:11 PM
10/09/13 07:11 PM
Challenger 1
Cincinnati, Ohio
Yup... ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: MASSMOPAR]
#1513439
10/09/13 07:18 PM
10/09/13 07:18 PM
Challenger 1
Cincinnati, Ohio
No Collapsing - no spring - no backwards
How in the hell do you know when your driving down the road that the lower hose is not collapsing? if it don't have a spring inside the lower hose?. If it doesn't have a spring than that's the part of the problem!!! ![](/ubbthreads/images/graemlins/rolleyes.gif)
