REBUILT 440 ENGINE overheats - HELP.
#1513381
10/07/13 09:06 AM
10/07/13 09:06 AM
Posts: 1,336 Massachusetts, USA
MASSMOPAR
Massachusetts, USA
I got this rebuilt 440 hp .030 engine --- Fires up runs great. BUT under normal driving conditions she overheats - temp goes thru the roof. Tried changing the water pump and the thermostat had no effect. The radiator is hot on the bottom and cold at the top. TOOK the thermostat completely out and temp stays at 170 degrees - but I know that is not the correct solution. What is going on?
70 Road Runner 528 HEMI 4sp FY1
70 Road Runner 440+6 V-Code AG 4spd EV2
69 R/T 4 Spd Dana 3:54 AG Vert B5
69 R/T 4 Spd Dana 3:54 AG X9 V1X V8R-WORKING
69 R/T Auto/Console 8.75 SG Vert R/T B3
08 Challenger 1st Edition Hemi Orange
69 Super Bee 4 Spd 8.75 SG AG F8
Re: REBUILT 440 ENGINE overheats - HELP.
[Re: MASSMOPAR]
#1513383
10/07/13 09:55 AM
10/07/13 09:55 AM
Posts: 5,122 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
Have to look at each piece of the puzzle separately. Fresh engine was it hot tanked and cooling passages cleaned and then recleaned and visually inspected. The Water pump and housing are they mated and just what water pump are you using. The rad, is it new has it been recored, what rad is it and how many cores. Thermostate I run 160 but other temps are fine when your system is working perfectly. Is this motor completely stock with no adjustable rockers and everything like cam timing and distributor timing set correctly. All thing I have mentioned can affect how hot the motor runs. There are a lot more things that affect motor heat. Look at one part of the cooling system at a time. Start with the RAD since you say it is cool on the top and hot on the bottom.
1971 HEMI E BODY REGISTRY
[Re: MASSMOPAR]
#1513385
10/07/13 10:09 AM
10/07/13 10:09 AM
RapidRobert
With no stat & back out in the same driving conditions the overheating problem dissappeared? That'd almost sound like the stat was upside down or something in the stat housing was keeping the stat from completely opening when it was in there or just a bad stat & possibly the second stat could be bad also. Assuming the timing is in the ballpark & I'm thinking that it is I would have a rad shop pump it up to 15 lbs when hot & see if it holds pressure (head gasket/cracked block or head(s) & if good there then as said the radiator. I'm assuming it runs hot around town and out on the hiway?. Holler how it goes. EDIT FastMark may be on to it (but I would say head gasket cooling holes) especially if it did not overheat before it was rebuilt & now after the rebuild it does overheat & the same rad was used. PS how hot is it getting?
[Re: dogdays]
#1513387
10/07/13 01:01 PM
10/07/13 01:01 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
The key is it ran fine without the thermostat. So it's not the head gasket or block or heads or radiator, it's the thermostat. If you must, leave it out until you can find one that works or how to install it.
R.
x2
[Re: MASSMOPAR]
#1513389
10/07/13 01:28 PM
10/07/13 01:28 PM
Posts: 28,069 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Check out this thread and it'll probably cover what you need.
[Re: JohnH]
#1513390
10/07/13 04:04 PM
10/07/13 04:04 PM
MASSMOPAR
Massachusetts, USA
Hi John - Yes -- what is the difference between AC water pump and non ac water pump? I put an A/C water pump in - I thought it would not make any difference. thanks The pump on the left is NON-AC and the pump on the right was in the engine when overheated. The fins are in a different direction.
[Re: MASSMOPAR]
#1513393
10/07/13 04:51 PM
10/07/13 04:51 PM
RapidRobert
Those are both non AC 8 blade pumps (& I prefer an 8 blader) & the one on the right appears to be more rugged with slightly more vane area to capture water. Unless the impeller is slipping on the shaft (not likely) then the problem is elsewhere
[Re: RapidRobert]
#1513394
10/07/13 04:54 PM
10/07/13 04:54 PM
MASSMOPAR
Massachusetts, USA
The temperature pegs - not just running hot I think there may be something to this A/C water pump vs non AC water pump, (I hope) Going to install 160 deg t-stat and this non-ac pump tomorrow-see if that does it. hate to think head gasket issue. thanks for your insight and comments.
[Re: RapidRobert]
#1513395
10/07/13 04:57 PM
10/07/13 04:57 PM
MASSMOPAR
Massachusetts, USA
The direction of the impeller matters not? What is the diff between ac/non ac? Thanks
[Re: Challenger 1]
#1513397
10/07/13 05:00 PM
10/07/13 05:00 PM
MASSMOPAR
Massachusetts, USA
Holley 770 street avenger
[Re: MASSMOPAR]
#1513399
10/07/13 05:05 PM
10/07/13 05:05 PM
RapidRobert
big block pumps draw coolant in at the center open side & sling it outward & with the clockwise rotation in mind it would appear that the pump on the right in addition to having larger vanes (at least in the pic appearance) & that the horizontle back support part of the vanes is in front rather than trailing like in the left pic which would lead me to believe that it would capture/sling more water. But the problem IS elsewhere. To answer your Q an AC pump has 6 vanes
[Re: JohnH]
#1513400
10/07/13 05:09 PM
10/07/13 05:09 PM
MASSMOPAR
Massachusetts, USA
Yes - the 26in radiator is brand new from year one. You mentioned AC vs NON ac water pump - will that make a diff?
