!@#$#@$ Durango lower ball joint #1512880
10/05/13 06:29 PM
10/05/13 06:29 PM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
Ok, today is ball joint day on my 2000 2wd Durango. I got all four rivet heads cut off and NONE of them would punch out the bottom, so I cut the bottom off one and it wouldn't punch up. So, I removed the control arm (bushings didn't look good anyway). I tried the press on one rivet form both side, no budge...
So, WHAT'S the deal with these? The FSM is no help because they expect you to replace the entire arm. The lower joint has steel parts of the control arm on both sides of the joint. My temptation is to cut out the welded in bottom side...
Re: !@#$#@$ Durango lower ball joint [Re: Jim_Lusk] #1512881
10/05/13 06:42 PM
10/05/13 06:42 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Why not just replace the arm? It isn"t that much more then paying for a good ball joint and bushing.
Re: !@#$#@$ Durango lower ball joint [Re: stumpy] #1512882
10/05/13 06:52 PM
10/05/13 06:52 PM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
Why not just replace the arm? It isn"t that much more then paying for ball joint and bushing.
It's more than double...I got some Moog joints for a GREAT price and the Moog bushings are under $20 for one arm. The crap (Master Pro) that O'Reilly's sells is $153/arm (I got all four ball joints for about $180). The prices are better at Rock, but then it's down and unless I go with the Moog ($117 plus shipping) I don't know the quality and I'm still spending more money.
Re: !@#$#@$ Durango lower ball joint [Re: Jim_Lusk] #1512883
10/05/13 07:02 PM
10/05/13 07:02 PM
Grand Prairie,Texas
Grand Prairie,Texas
How about drilling out the rivets? I don't think I'd start hacking on the arm myself.
Re: !@#$#@$ Durango lower ball joint [Re: stumpy] #1512884
10/05/13 07:07 PM
10/05/13 07:07 PM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
I'd rather not distort the holes, cutting and welding makes more sense, in my opinion (that and it really easier and quicker as there is no way to mount this thing level in the drill press).
Re: !@#$#@$ Durango lower ball joint [Re: Jim_Lusk] #1512885
10/05/13 07:10 PM
10/05/13 07:10 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
hmmm
wonder why?
Think, McFly, think
Don't be the exception.
Re: !@#$#@$ Durango lower ball joint [Re: Jim_Lusk] #1512886
10/05/13 07:20 PM
10/05/13 07:20 PM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
I've had luck with some riveted balljoints drilling in the center of the rivets enough to weaken them. Then they punch through.
I can't remember my last 2000 durango but some of the gms were pricks to do!
Re: !@#$#@$ Durango lower ball joint [Re: MPerry] #1512887
10/05/13 08:15 PM
10/05/13 08:15 PM
NY NY
3
340duster340 Offline
NY NY
are you using an air chisel and still not budging?
Re: !@#$#@$ Durango lower ball joint [Re: 340duster340] #1512888
10/05/13 09:20 PM
10/05/13 09:20 PM
Alexandria, NJ
WayneM Offline
WayneM  Offline
Alexandria, NJ
I'm assuming '98 is the same? I just knocked the heads off mine with an air hammer with a sharpened chisel. IIRC, I put a block of wood to prop up the arm and gave it a good slug. I use MOOG problem slovers with the fittings exclusively.
2014 Durango R/T
2004 Dodge Ram 3500 SRW SLT short quad Cummins 6 speed
1998 Dodge Durango SLT 5.2
1971 Plymouth Duster-
<<<<<MOPAR SPOKEN HERE>>>>>
Re: !@#$#@$ Durango lower ball joint [Re: WayneM] #1512889
10/05/13 09:24 PM
10/05/13 09:24 PM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
Yeah, I watched a couple of videos and both buys drilled out the center. That does two things, keeps the punch in place and cause a stretch to slightly shrink the size. I got one side out, now to go get lower bushings and the rack...Good thing I got a great deal on the Durango almost two years ago, it doesn't hurt so bad now spending a few hundred on it.
Re: !@#$#@$ Durango lower ball joint [Re: Jim_Lusk] #1512890
10/05/13 11:52 PM
10/05/13 11:52 PM
Randolph, Ohio--N.E. Ohio
Goat330 Offline
Goat330  Offline
My 2000 Ram Sport has the riveted ball joints and I replaced them a year ago. Get a good drill and plenty of good bits because that's the only way my would budge.When you drill almost to edge of the rivet, then the air chisel will pop them out.
Re: !@#$#@$ Durango lower ball joint [Re: Goat330] #1512891
10/06/13 02:10 AM
10/06/13 02:10 AM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
Yeah, that's what I wound up doing. That air chisel is gonna kill my elbow (that's been hurting for weeks now), though.
I also found where I've been losing coolant. It's a slow leak and I figured I'd go look for it soon. Well, looks like both freeze plugs behind the motor mounts are leaking and probably the rear one on each side. It looks like the front ones have already been replaced...
Re: !@#$#@$ Durango lower ball joint [Re: Jim_Lusk] #1512892
10/08/13 11:52 PM
10/08/13 11:52 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Thanks for posting this. I am about to do the same thing on my 2003, as well as the half shafts that are clicking. I think I will got with the arms
Craig
Re: !@#$#@$ Durango lower ball joint [Re: denfireguy] #1512893
10/09/13 02:29 AM
10/09/13 02:29 AM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
I finally got them done. The good news is my elbow pain seemed to be from lack of use (I've been doing on-line school for the last six months or so and ignoring most of the car stuff). Arms were just out of the budget. I did finally get the last freeze plug in (had to borrow a tool from a buddy). Might get it all back together tomorrow night...
Re: !@#$#@$ Durango lower ball joint [Re: Jim_Lusk] #1512894
10/09/13 06:18 AM
10/09/13 06:18 AM
Alexandria, NJ
WayneM Offline
WayneM  Offline
Alexandria, NJ
The first gen Durango is not a bad truck to work on. Just don't try to change the cat converter unless you REALLY need to!
2014 Durango R/T
Re: !@#$#@$ Durango lower ball joint [Re: Jim_Lusk] #1512895
10/09/13 10:40 PM
10/09/13 10:40 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
I have a 99 2WD Durango and the pass side upper ball joint had failed a few years back. Took it to dealer and they were of no help. Called Chrysler customer assistance regarding the failure (it was on national news back then about all Dakota/Durango ball joint failures) and proved my 99 had a late build date. Chrysler customer assistance called back and said that they would cover all four ball joints.... PARTS and Labor!!!!
Re: !@#$#@$ Durango lower ball joint [Re: mercman1] #1512896
10/09/13 11:46 PM
10/09/13 11:46 PM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
I'm a little late on this one, but they didn't fail, they just wore out. The wheels go back on tomorrow and then I'll align it.
Re: !@#$#@$ Durango lower ball joint [Re: Jim_Lusk] #1512897
10/19/13 10:31 PM
10/19/13 10:31 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Well I decided to be lazy and order both arms. NAPA was 0 for 4 on getting me the right arms. My first clue was they had to get them from Billings Montana. The lower arms look like they are for a Dakota since they to not have the torsion bar socket and looks like the bottom of a coil recess. The uppers had 1/2 inch bolts and the orginals are 9/16. Both are going back.
Meanwhile, I had the lowers press fitted in by NAPA and I used a cut off tool on the uppers. I also am replacing the half shafts since they are whining and clicking.
Re: !@#$#@$ Durango lower ball joint [Re: denfireguy] #1512898
10/20/13 09:33 AM
10/20/13 09:33 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I had a bad one on my 99 4 WD a few years ago.It only had at the time 70K miles.It took me about 1 1/2 hours to do all 4 at the shop.Biggest advantage was having a lift.They were some of the easiest that Ive changed.Having a good air chisel also helps along with a good impact.Rocky
Chrysler Firepower
Re: !@#$#@$ Durango lower ball joint [Re: denfireguy] #1512899
10/20/13 01:34 PM
10/20/13 01:34 PM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
Sounds like you got 2WD parts...Dakota and Durango used the same front end parts, but 4wd arms were different.
