Re: Super Blue Brake Fluid not legal in the USA ?
[Re: PHJ426]
#1512193
10/04/13 04:49 PM
10/04/13 04:49 PM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
For those who might buy some for the shelf...
From ATE: Life expectancy:
All Brake Fluids With temps between -20 C and 40 C up to 5 years in the initially closed tins. * once opened, use within 1 year
Datecodes on the product: Brake Fluid Container: Day it was filled marked as day XXX plus year Y, e.g. 0787 = 78th day of 2007
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
[Re: Uhcoog1]
#1512194
10/04/13 04:59 PM
10/04/13 04:59 PM
Posts: 2,467 Answering the call of the wild
ThermoQuad
Part No.: 3327-Quantity ATE Type 200 (Amber) DOT 4 Racing Brake Fluid ATE Type 200 (Amber) DOT 4 Brake fluid is an ideal choice for handling the high demands placed on your brake system, regardless of whether you are involved in autocross, road racing or high performance street driving. ATE Type 200 (Amber) Specifications: DOT Rating: 4 Dry Boiling Point: 536° F Wet Boiling Point: 396° F Compatible With Other Fluids: Yes Container: One liter metal can ATE Type 200 is the same as ATE Super Blue Racing Brake Fluid, except with a DOT-compliant amber color. All other specifications are identical. ATE engineered the two fluids to have exactly the same performance. pegasus racing
[Re: Uhcoog1]
#1512196
10/04/13 05:06 PM
10/04/13 05:06 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Ive benn running Motul RBF 600. Is it comparable/equal to the ATE?
Mopar to the bone!!!
[Re: PHJ426]
#1512201
10/04/13 10:50 PM
10/04/13 10:50 PM
Posts: 2,432 NorCal
RylisPro
NorCal
How fresh was it when you boiled the Super Blue fluid?
I used a fresh brand new sealed bottle like I always do before each trackday, boiled at the next to last session at Thunderhill this past spring. Flushed it with Castrol SRF and did the same in the summer with higher ambient temps and pedal feel felt awesome all of the session start to end
[Re: PHJ426]
#1512202
10/05/13 11:55 AM
10/05/13 11:55 AM
Posts: 805 San Francisco Bay Area
MrAngry
Motul RBF600 or RBF660. Match that up with a good set of pads, rotors and lines and you're good to go.
Never trust a pretty girl... or a lonely midget.
