70 Challenger parking brake cables #1512187
10/04/13 03:13 PM
10/04/13 03:13 PM
pa.
dan9 Offline OP
dan9  Offline OP
pa.
Looking through the Classice catalog they list e-brake cables 2 ways. One has an intermediate cable and one doesn't. What dictates which one to use. I only have remnants of the cable attached to the e-brake,about 2 feet long if I remember correctly. Eveything else was missing. Thank you
Re: 70 Challenger parking brake cables [Re: dan9] #1512188
10/04/13 03:24 PM
10/04/13 03:24 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
1970 didn't use an intermediate cable. 71-74 did.(there may be exceptions) The 1970 front cable goes all the way back and connects to the two rear cables. The rear cables are different lengths. There is one bracket that is welded to the ds frame rail that both rear cable clip into.
When the intermediate cable is used, both rear cables are the same length and clip to little brackets on each frame rail.
Re: 70 Challenger parking brake cables [Re: burdar] #1512189
10/07/13 10:38 AM
10/07/13 10:38 AM
pa.
dan9 Offline OP
dan9  Offline OP
pa.
Thanks for the help. My parking brake assembly looks to be original and has a cable about 3 feet long. The ds bracket near the spring hanger only has one hole. I assume I need the equal length rear cables and an equalizer bar? Thank you
