2 circuit versus 3 circuit Dominators #1511608
10/02/13 07:58 PM
10/02/13 07:58 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
How much of an advantage do 3 circuit Dominators have over 2 circuit Dominators is a drag car? The car in question is my Coronet that makes around 800 hp and runs 9.60's.
Re: 2 circuit versus 3 circuit Dominators [Re: markz528] #1511609
10/02/13 08:17 PM
10/02/13 08:17 PM
AndyF Offline
AndyF  Offline
Subject that has been debated over the years. The 3 circuit should be better but they sometimes require a ton of tuning to get the intermediate circuit working correctly in the car. The intermediate circuit is very sensitive to part throttle (super rich at part throttle) so it depends on how you leave the line. If you hold the engine at part throttle against the brake then a three circuit probably won't work for you.
Best deal is to call a carb shop and discuss it. I went back to a two circuit 1250 on my 514 engine. The guys at BLP told me the two circuit is adequate up to about 900 hp and then you need the third circuit, but it really depends on the application.
Re: 2 circuit versus 3 circuit Dominators [Re: AndyF] #1511610
10/02/13 08:45 PM
10/02/13 08:45 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
That makes a lot of sense. I have a 3 circuit now that I believe is not set up right. My buddy has a 1050 Dominator 2 circuit for sale from a roundy round car (too big for them) at a reasonable price and I was wondering if I should try it. Sounds like it may be a good idea. I'm sure I could borrow it without committing to buy it.
Currently I'm leaving on the brake at 3500 rpm with the pedal to the floor. I have been leaving around 4500 rpm in the past.
Re: 2 circuit versus 3 circuit Dominators [Re: markz528] #1511611
10/02/13 10:01 PM
10/02/13 10:01 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I thought the 3 circuit helped cars on the brake with pedal to the floor because air isn't moving fast enough past the boosters
Re: 2 circuit versus 3 circuit Dominators [Re: markz528] #1511612
10/02/13 11:21 PM
10/02/13 11:21 PM
AndyF Offline
AndyF  Offline
If you can borrow the 2 circuit then give it a try. If it is setup up close for your combination it might just work.
You can also make some changes to your 3 circuit. It is best to have a wide band to set up a 3 circuit but you can do it old school also. One easy thing to try is to remove the intermediate air bleeds and see how it runs. Holley left the air bleeds out on some 3 circuit carbs. You can also reduce the jet size on the intermediate circuit just to see how it works. Every 3 circuit that I've ever worked on was dead rich in the intermediate circuit and needed to be leaned out a ton.
Re: 2 circuit versus 3 circuit Dominators [Re: AndyF] #1511613
10/03/13 12:18 AM
10/03/13 12:18 AM
Cab_Burge Online work
Cab_Burge  Online Work
Re: 2 circuit versus 3 circuit Dominators [Re: AndyF] #1511614
10/03/13 08:20 AM
10/03/13 08:20 AM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
That is exactly what I was thinking. In the process of installing the new Racepak data logger so I will have air fuel ratio monitoring next time out.
With the 80 intermediate air bleeds in the carb now I think I am WAY rich and that is why the car works so much better on the launch as the weather gets cooler.
Re: 2 circuit versus 3 circuit Dominators [Re: markz528] #1511615
10/03/13 09:59 PM
10/03/13 09:59 PM
crisfield, maryland 21817
8
82ramIndy493 Offline
Call Jesse at Bigs Performance. He can do the conversion from 3 to 2 cuircuit. He just did mine last year and I am satisfied with it and didn't see any loss of time with it. He can tell you if it will help or hurt you.
