Brake line routing tech #1511577
10/02/13 06:18 PM
10/02/13 06:18 PM
MN
JERICOGTX Offline OP
MN
I am installing a roll cage in a coworkers 71 Demon. He has installed a line lock under the dash, and routed the brake lines in the passenger area. Is that even legal per NHRA?
Thanks.
Jeff
69 GTX 68 Road Runner
Re: Brake line routing tech [Re: JERICOGTX] #1511578
10/03/13 12:51 PM
10/03/13 12:51 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Hey Jeff, I don't know the answers to your question. But I do have a PDF of the 2013 NHRA rules somewhere in my computer. I could shoot it over to you via email if that would help.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Brake line routing tech [Re: JERICOGTX] #1511579
10/03/13 01:53 PM
10/03/13 01:53 PM
Az
Crizila Offline
Crizila  Offline
Az
---- "brake lines must be steel, steel braided, or DOT approved flexible and routed outside the frame rail, or enclosed in a 16" length 1/8" minium wall thickness tubing securely mounted where lines pass the flywheel bellhousing area and not routed in the driveline tunnel." Lines must be securely mounted per OEM style ---- this from the general section of the 2013 rule book. The big concern should be the bellhousing area ( don't ask me how I know ). If possible, all lines should be in front of the firewall area excluding the one line to the rear brakes. For sure all lines passing the bellhousing area need to be enclosed. Keeping lengths and bends to a minimum is always beneficial.
Fastest 300
Re: Brake line routing tech [Re: Crizila] #1511580
10/03/13 01:59 PM
10/03/13 01:59 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
outside the frame rails or enclosed in a steel tube?
how strictly is that enforced? what if your brake lines are 100% original as the vehicle left the factory? on my Dakota the rear lines travel along the inside of the frame tucked up next to the fuel line, which is also inside the frame.
**Photobucket sucks**
Re: Brake line routing tech [Re: 70Cuda383] #1511581
10/03/13 02:45 PM
10/03/13 02:45 PM
Az
Crizila Offline
Crizila  Offline
Az
Most OEM lines run inside the frame rail. My 63 Max wedge car had original brake lines running along the inside of the frame rail when I had a BAD clutch explosion. Coasted through the lights at 78 MPH with NO BRAKES . All of todays cars have dual braking systems, but I would not like to have to stop my "train" @ 130 with just the front or rear brakes. Don't know how strictly it is enforced, but there are a lot of very fast cars out there with OEM brake systems. Just because it is OEM don't make it safe.
Fastest 300
Re: Brake line routing tech [Re: Crizila] #1511582
10/03/13 05:31 PM
10/03/13 05:31 PM
Q
Quicktree Offline
Quicktree  Offline
Q
that is on the outside of the firewall
Re: Brake line routing tech [Re: Quicktree] #1511583
10/03/13 06:06 PM
10/03/13 06:06 PM
Az
Crizila Offline
Crizila  Offline
Az
"where they pass the firewall bellhousing AREA". Guess you get to interpret that any way you want.
Fastest 300
Re: Brake line routing tech [Re: Crizila] #1511584
10/03/13 06:43 PM
10/03/13 06:43 PM
Truckville, the capital of NY
85_Ram_4speed Offline
I know there are guys out there who mount pressure gauges in the car for for setting a certian amount of brake on the starting line... so what whould be the difference?
I would feel better with a certian amount of brake line in the car myself vs being on the outside exposed to possible danger /damage. My old Dartsport I ran the rear line from the M/C to a grommet in the firewall and ran it right down the interior along the top of the rocker under the sill plate and back seat area. I used a longer brake hose from the rear end to meet up to the floor pan behind the rear seat brace. That way it was away from any drivetrain and protected from something on the outside damaging it.
When I redid the car, I ran the front pass side down the drivers side, along the core support and down the right side to the wheel. But being a stic k car, I was thinking safety from the bellhousing area. However, a front end accident could have damaged that easily too---so pick your poison.
I know it doesn't answer your question at all, but I think as long as it is done safely, no one is going to bother you --or him.
Outcast Dodge guy.
Re: Brake line routing tech [Re: 85_Ram_4speed] #1511585
10/03/13 08:52 PM
10/03/13 08:52 PM
Az
Crizila Offline
Crizila  Offline
Az
I would guess you are right - as long as there is something (floor, etc. ) between the brake line (s) and bellhousing and it is not in the tunnel area.
Fastest 300
