Brake line routing tech
#1511577
10/02/13 06:18 PM
10/02/13 06:18 PM
Posts: 10,022 MN
JERICOGTX
MN
I am installing a roll cage in a coworkers 71 Demon. He has installed a line lock under the dash, and routed the brake lines in the passenger area. Is that even legal per NHRA?
Thanks.
Jeff
69 GTX
68 Road Runner
Re: Brake line routing tech
[Re: JERICOGTX]
#1511578
10/03/13 12:51 PM
10/03/13 12:51 PM
Posts: 7,490 Minnesota
Hemi_Joel
Minnesota
Hey Jeff, I don't know the answers to your question. But I do have a PDF of the 2013 NHRA rules somewhere in my computer. I could shoot it over to you via email if that would help.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: JERICOGTX]
#1511579
10/03/13 01:53 PM
10/03/13 01:53 PM
Posts: 7,506 Az
Crizila
Az
---- "brake lines must be steel, steel braided, or DOT approved flexible and routed outside the frame rail, or enclosed in a 16" length 1/8" minium wall thickness tubing securely mounted where lines pass the flywheel bellhousing area and not routed in the driveline tunnel." Lines must be securely mounted per OEM style ---- this from the general section of the 2013 rule book. The big concern should be the bellhousing area ( don't ask me how I know ). If possible, all lines should be in front of the firewall area excluding the one line to the rear brakes. For sure all lines passing the bellhousing area need to be enclosed. Keeping lengths and bends to a minimum is always beneficial.
Fastest 300
[Re: Crizila]
#1511580
10/03/13 01:59 PM
10/03/13 01:59 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
outside the frame rails or enclosed in a steel tube?
how strictly is that enforced? what if your brake lines are 100% original as the vehicle left the factory? on my Dakota the rear lines travel along the inside of the frame tucked up next to the fuel line, which is also inside the frame.
**Photobucket sucks**
[Re: Crizila]
#1511582
10/03/13 05:31 PM
10/03/13 05:31 PM
Quicktree
that is on the outside of the firewall
[Re: Crizila]
#1511584
10/03/13 06:43 PM
10/03/13 06:43 PM
Posts: 3,325 Truckville, the capital of NY
85_Ram_4speed
I know there are guys out there who mount pressure gauges in the car for for setting a certian amount of brake on the starting line... so what whould be the difference?
I would feel better with a certian amount of brake line in the car myself vs being on the outside exposed to possible danger /damage. My old Dartsport I ran the rear line from the M/C to a grommet in the firewall and ran it right down the interior along the top of the rocker under the sill plate and back seat area. I used a longer brake hose from the rear end to meet up to the floor pan behind the rear seat brace. That way it was away from any drivetrain and protected from something on the outside damaging it.
When I redid the car, I ran the front pass side down the drivers side, along the core support and down the right side to the wheel. But being a stic k car, I was thinking safety from the bellhousing area. However, a front end accident could have damaged that easily too---so pick your poison.
I know it doesn't answer your question at all, but I think as long as it is done safely, no one is going to bother you --or him.
Outcast Dodge guy.
[Re: 85_Ram_4speed]
#1511585
10/03/13 08:52 PM
10/03/13 08:52 PM
Posts: 7,506 Az
Crizila
Az
I would guess you are right - as long as there is something (floor, etc. ) between the brake line (s) and bellhousing and it is not in the tunnel area.
Fastest 300
