Re: 340 smallblock screamer [Re: goldmember] #1511534
10/05/13 02:35 PM
10/05/13 02:35 PM
Outside
thedriver Offline
thedriver  Offline
Outside
That motor will make 320 to the tire.
It very well may but I'd think that would be a gross under achiever. why do all that for a 400hp build?
I was figuring slightly over 100hp loss to tire, so say 440hp. Which, in magazine world is probably 470hp.
Want 10s with a 340/ 727 demon?
Get a better head ( w2) get a biiiiiig solid cam think 7500ish rpm peak, get a converter in the 5000+rpm range. Make it really light.
That should get you close.
Wouldn't worry about any bigger carb than the 750.
550hp 340 that rolls on the street? Dream on.
1973 challenger
Dana. 4 speed. Low deck.
Re: 340 smallblock screamer [Re: thedriver] #1511535
10/05/13 04:53 PM
10/05/13 04:53 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I've never(on a good chassis dyno,and yep they vary all over the map) seen near the losses your predicting. 18% is the norm 400fwhp will put down 320rwhp happens all the time.
Re: 340 smallblock screamer [Re: goldmember] #1511536
10/08/13 01:24 AM
10/08/13 01:24 AM
rancho cucamongs ca 91710 usa
W
watermans340 Offline OP
W
Well it seems everyone has an opinion and ill admit I don't agree with many of them. Apparently someone has already built my exact motor and knows what power it will make lol.I don't think a hi 10 second 2800 to 2900 pound a body is out of the possibility. And with the head flow #s I think 500 plus hp is very doable.as far as streetability goes I never said I'd be crusing the highway but you can believe it will be a 100 percent street strip car.insured.registered exc.o yea and the whole plan is th whip on every ford n chevy that pulls up next to me at a red light! Its not a drag car its a overall total package car!
Re: 340 smallblock screamer [Re: watermans340] #1511537
10/08/13 01:39 AM
10/08/13 01:39 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I hope it runs 10s for you. The weight will make that easier.
I have something similar. 68 Barracuda 3500lbs, 360, 11:1, shady dell stage 2 port edelbrocks, solid roller, victor intake, 830 Holley, tti headers and a full exhaust system, 4500 8" ta converter, 727, 3.91 gears, 275/50 drag radials. Still ironing some things out but it's been a best of 11.37 and a best mph of 117.5. I let off before the mph traps on its best et run so the mph was way low. I haven't had it back out since drag week where it ran those numbers.
I wanted this combo to be in the tens and it likely won't get there. If it does make it there it will have to have more converter(5000-5500) and a low gear 904. The small tti headers likely don't help it any either.
68 Barracuda Formula S 340
Re: 340 smallblock screamer [Re: Bad340fish] #1511538
10/08/13 08:25 AM
10/08/13 08:25 AM
Guitar Jones Offline
Well having ran a 340 for many years I can tell you this, you really do have to wing it to make the horsepower. I was turning mine to 8000 rpm's. It requires a lot of gear (I was using a 5.13 with a 30" tall tire) and a low gear 904 really helps it. It would be SO much easier to do with a stroker though.
Re: 340 smallblock screamer [Re: Guitar Jones] #1511539
10/08/13 03:40 PM
10/08/13 03:40 PM
Outside
thedriver Offline
thedriver  Offline
Outside
I can't even begin to tell you how much time and money I've pissed away into 340's over the years to learn the hard way.
They make a great street package due to low torque, therefore quick to hookup on crappy tires while the other guy spins. On the track, like already mentioned, lots of converter, and lots of gear, so much of both that it becomes no fun to drive anywhere on the street real quick.
Fwiw, I've got a similar 340 to what you are trying to put together that was on my car before I went for more ci. I use a comp xehl 285 with .545 lift. Shift just past 6000.
When I had a 3.91 gear, and 3400 stall that thing would never '60 better than 1.85. That low stall killed it, but it's a street car too, happy medium ya know?
Was good for corrected 12.0's @ 3500lb, which, for what it is, is smoking.
There's a good reason why strokers are the rage.
And if you can get 500hp out of a 340 with flat tappet hyd cam thats done by 6200 ish and stock head in a 3.31" stroke I'll be calling you for lessons.
1973 challenger
Re: 340 smallblock screamer [Re: thedriver] #1511540
10/08/13 04:31 PM
10/08/13 04:31 PM
West Michigan
76318dart Offline
76318dart  Offline
West Michigan
I run a stroker and love it. My dad runs a 340 in his dart. Weighs 3500 w/him. He runs 12.20s with his and its best 60ft was 1.69 that's with 3800 stall and 430s. But now day's stroker is where its at.
76 dart 318 runs 12.9o @ 103 mph with 1.78 60ft.
Re: 340 smallblock screamer [Re: Guitar Jones] #1511541
10/08/13 05:08 PM
10/08/13 05:08 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Even at 2900# you will need a bunch of gear, converter and RPMs. My 340 had ported Edelbrocks, a 237/242 @ .050 .590ish lift hydraulic cam, 11.2-1 compression, 727 with a 4500 converter and 4.30 gears and 28" tires. At 3260 or so pounds it went 7.24 in the 1/8 and low 11.60 in the 1/4. It ran on pump 93 and I drove it everywhere just like I do my 408 now.
