340 smallblock screamer #1511514
10/02/13 04:47 PM
10/02/13 04:47 PM
rancho cucamongs ca 91710 usa
W
watermans340 Offline OP
W
hey guys i finally got back into building my 340 in my 71 demon. i wanted to to see if i can get some responces on my plan to see what you all think. stock stroke 340 factory forged crank and rods with forged pistons 0.040 over and about 10 out of the hole plan on running cnc ported (runners and bowls) eddy performer rpm heads, 2.02 intake and 1.60 exhaust valves with a comp cams hydrolic flat tappet (.564 lift on intake and exhaust and 251 257 duration) i will have to use 1.6 rockers bringing the lift to just over .600 topped off with performer rpm air gap (home ported) manifold and either my 770 street avenger with vacume secondaries or 750 double pumper and dougs 1 5/8 headesr. i know i should use a 850 or 950 carb and large tube headers but money is always the issue. what do you guys think of my set up and what do you think it will make in hp? thanks for any input!!!
Re: 340 smallblock screamer [Re: watermans340] #1511515
10/02/13 05:13 PM
10/02/13 05:13 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Too many issues running hydraulic lifters today, quality aint there in the lifter mechanisms imo. Go solid. And put some money inside the bellhousing esp with stock stroke.
Re: 340 smallblock screamer [Re: watermans340] #1511516
10/02/13 05:30 PM
10/02/13 05:30 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
And .010 out of the hole will need a thicker head gasket than a standard felpro with a closed chamber head.
Re: 340 smallblock screamer [Re: watermans340] #1511517
10/02/13 05:52 PM
10/02/13 05:52 PM
W. Kentucky
justinp61 Online content
justinp61  Online Content
W. Kentucky
Measure the piston to valve clearance with that much lift and the pistons .040" out of the hole. I'd use good rod and main bolts and a single plane intake, something like a Weiand X-Cellerator would work great. Oh yeah, a good balance job is a must if you are going to spin it up. Not real big on a hydraulic cam this big either.
Re: 340 smallblock screamer [Re: Hot 340] #1511518
10/02/13 05:53 PM
10/02/13 05:53 PM
Guitar Jones Offline
I ran my 360 with pistons .011 out of the hole with the standard .039 FelPro and small chamber W5's without issues for 15 years buzzing it to 7500. I'm not saying you should do that, it was just the way mine ended up with the parts I had and the very limited 4 day time schedule to put it together while still holding down a 12 hour a day job. Piston to valve clearance was very tight too at .076/.083, you can believe I was puckering the first time I winged it in the water box.
Re: 340 smallblock screamer [Re: Guitar Jones] #1511519
10/02/13 05:59 PM
10/02/13 05:59 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
I woulda been puckering too, man that is tight!
Re: 340 smallblock screamer [Re: watermans340] #1511520
10/02/13 06:24 PM
10/02/13 06:24 PM
Are the Eddy heads a open chamber like the stock X and J heads are? If so make sure your piston to head clearances are sufficent for the RPM you want to run I like and shoot for a mininum of .035
Re: 340 smallblock screamer [Re: watermans340] #1511521
10/02/13 06:33 PM
10/02/13 06:33 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
That cam is more suited to a stroker. I tried one in my 340 installed per factory specs and ended up replacing it w/a Racer Brown that netted almost .4 in ET. Thinking back, if I would have advanced it 3 deg, it would have been close to the Racer Brown open/closing specs.
Yeah, it's got a smallblock.
Re: 340 smallblock screamer [Re: 340B5] #1511522
10/03/13 12:47 AM
10/03/13 12:47 AM
W
W
heads are closed chamber 64cc. 10.5 to one compression. .035 quench. is there any bad ideas or flaws in my components??
Re: 340 smallblock screamer [Re: watermans340] #1511523
10/03/13 03:40 AM
10/03/13 03:40 AM
How thick are your head gaskest? Did you check piston to head clearances yet? I had a set of dished stroker pistons hitting both sides of the edges of the cylinder heads(cam and outside block side) of the combustion chambers with .039 thick head gaskets with the pistons at zero deck hieght The pistons will rock at TDC, hence only the outside edges of the pistons touching, it was not noticeable when turning the motor over with the spark plugs out when degreeing the cam and again when I checked the net valve lift at each retainer with the actual valve springs and valve lash set cold Evidently with the motor warmed up at WOT the pistons and rods grew enough to allow the piston edges to touch, no noise, no loss or gain of power once I switched the head gaskests to a thicker set of MLS I strongly suggest checking every piston to head clearances by putting the pistons at TDC with the heads on and torque down and then remove the rod caps and put a dial indicator on the rod and push the rod up into the head and see how much actual clearances to the heads you have cold on every piston
Re: 340 smallblock screamer [Re: Cab_Burge] #1511524
10/03/13 10:36 PM
10/03/13 10:36 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
i would not buy the cam until you flow the heads.
put the cam where the heads want to be
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: 340 smallblock screamer [Re: cheapstreetdustr] #1511525
10/03/13 10:56 PM
10/03/13 10:56 PM
W
W
Cheap street duster I believe they flow around 265/200 @ .500 lift doo you think .600 lift & 250ish duration is too much cam for a 340 0.040 over 10.5 compression? Begining to consider the roller cam again...
Re: 340 smallblock screamer [Re: watermans340] #1511526
10/03/13 11:14 PM
10/03/13 11:14 PM
W
W
According to cam quest this set up will make around 573 hp and 503 ft lbs. Generous #s I'm sure
Re: 340 smallblock screamer [Re: watermans340] #1511527
10/04/13 12:07 AM
10/04/13 12:07 AM
peak numbers are only a portion of it..
i would graph the flow and have a cam built the leverages your flow based on what you want to do with the car..
if the port is dead after .500" or goes turbulent then it would be unnecessary to go to .600"
thats an over simplification..but you get the idea
ill also say...lets say hypothetically .522" valve lift is a sweet spot in the port...than i would go just a lil past that valve lift so the port sees the sweet spot twice.once on the valves way up then again on the valves way down..
again this is over simplification ..but gives you some cause to do a little more home work.
some known combos have already sorted these things out.
but the/your hardware becomes the fixed items in the equation..the correct cam will put them to your advantage..fwiw
[image][/image]
Re: 340 smallblock screamer [Re: cheapstreetdustr] #1511528
10/04/13 06:41 PM
10/04/13 06:41 PM
W
W
ok final head specs; 190 intake runner, 2.02 intak 1.60 exhaust valves, flowing 272 and 230 at .600 lift and they can flow beyond that but i dont want to run more than .600 lift.64 cc closed chamber. engine is 340, .040 over, .010 outa the hole, .035-.040 quench,10.5 to 1 compression. i think 550hp is doable, and with the 3600-3800 stall converter and 430 gears spinning littlt 27 inch tall rear rubbers im hoping to dip into the 10s in the quarter.
Re: 340 smallblock screamer [Re: watermans340] #1511529
10/04/13 06:56 PM
10/04/13 06:56 PM
Renton Washington
Triple Threat Offline
Renton Washington
More converter
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: 340 smallblock screamer [Re: Triple Threat] #1511530
10/04/13 07:03 PM
10/04/13 07:03 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
More converter
and more cam,and prefereably more compression.
i think camquest is on some serious ilegal substanses with there hp predictions..
Re: 340 smallblock screamer [Re: 1Fast340] #1511531
10/05/13 01:25 AM
10/05/13 01:25 AM
Outside
thedriver Offline
thedriver  Offline
Outside
That motor will make 320 to the tire.
1973 challenger
Dana. 4 speed. Low deck.
Re: 340 smallblock screamer [Re: 1Fast340] #1511532
10/05/13 02:18 AM
10/05/13 02:18 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
More converter
Put a nice solid lifter cam in it and you have at least a chance. Camquest is garbage.
Re: 340 smallblock screamer [Re: thedriver] #1511533
10/05/13 02:22 AM
10/05/13 02:22 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
It very well may but I'd think that would be a gross under achiever. why do all that for a 400hp build?
