Passing Gear Linkage #151146
11/14/08 10:47 PM
11/14/08 10:47 PM
Sonoran desert, Arizona, USA
moparjo68 Offline OP
I'm working on a 68 Dodge Charger with a 383,HP high rise exhaust manifolds, and a 727 Tranny from a 70 Chrysler. Will the passing gear linkage from a 66 Chrysler fit on this Charger? I transfered the transmission control arm from the 66 Transmission onto the 70 transmission.
I tried hooking up the linkage, but I was having problems with it hitting against the high rise manifold. I do not have the linkage for the 68 Dodge nor do I have all of the linkage from the 70 transmission.
Thanks for any suggestions...all help appreciated.
Joe
Re: Passing Gear Linkage [Re: moparjo68] #151147
11/15/08 12:11 AM
11/15/08 12:11 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
On high rise intakes it is usually easier to go with a cable kick down like lokar or bouchillon.
Re: Passing Gear Linkage [Re: stumpy] #151148
11/15/08 12:38 AM
11/15/08 12:38 AM
Brandon, Ms
cornet684me Offline
cornet684me  Offline
Brandon, Ms
i went with bouchillon set up, works great
440 with eddy rpm intake
Re: Passing Gear Linkage [Re: moparjo68] #151149
11/16/08 12:46 PM
11/16/08 12:46 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
What ever you do make certain itis hooked up before driving.
That does more than work the passing gear.
I want my fair share
Re: Passing Gear Linkage [Re: moparjo68] #151150
11/16/08 01:15 PM
11/16/08 01:15 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
...high rise exhaust manifolds
This statement is confusing. Is it the intake or exhaust manifold you are talking about? Either way, I cannot visualize on how either intake or exhaust manifolds would interfer with the "linkage". Possibly some miss match of brackets, bellcrank and linkage could cause an interference with the exhaust manifold/head pipe flange or something. A little more info and maybe someone else will be able to answer your question.
Re: Passing Gear Linkage [Re: BSB67] #151151
11/16/08 01:26 PM
11/16/08 01:26 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
High rise intakes have a tendency to raise the linkage to the point it hits the firewall where it goes down and won't work.
Re: Passing Gear Linkage [Re: stumpy] #151152
11/16/08 01:45 PM
11/16/08 01:45 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
hmmm. I don't think that is what he said.
Re: Passing Gear Linkage [Re: BSB67] #151153
11/16/08 02:32 PM
11/16/08 02:32 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I was answering what you said about intakes.
Re: Passing Gear Linkage [Re: stumpy] #151154
11/16/08 03:11 PM
11/16/08 03:11 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
But you did not. You stated how the linkage might contact the firewall.
Re: Passing Gear Linkage [Re: BSB67] #151155
11/16/08 03:14 PM
11/16/08 03:14 PM
the problem is your going automatic and thats just wrong!!!!
Re: Passing Gear Linkage #151156
11/16/08 03:19 PM
11/16/08 03:19 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
is the best, or certainly the most fun
Re: Passing Gear Linkage [Re: BSB67] #151157
11/16/08 04:01 PM
11/16/08 04:01 PM
Port Alberni, British Columbia
MoparDonny Offline
MoparDonny  Offline
Too many grumpies on here that need another coffee.
Anyway. Your question is a bit confusing. WHat is hitting what? On my Challenger I had a higher carb than stock by a couple inches with a 3 piece kickdown linkage and HP exhaust maniflods and I don't ever recall a problem with clearances. I take it you have a 1 piece rod from the carb to the trans by the problems you have but just try to be a bit more specific as to what is hitting and exactly where.
Thanks, and good luck.
Don.
Re: Passing Gear Linkage [Re: MoparDonny] #151158
11/16/08 05:20 PM
11/16/08 05:20 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
"I cannot visualize on how either intake or exhaust manifolds would interfer with the "linkage"."
Visualize the higher mounting point on the higher intake raising the linkage pivot so that the part of the linkage going to the trans now hits the firewall. That is an example of what indirect interference the intake could cause. That's what happens with some the intake swaps. I hope that makes my answer eaiser for you to understand.
Re: Passing Gear Linkage [Re: stumpy] #151159
11/16/08 05:31 PM
11/16/08 05:31 PM
Stumpy you ARE the man
Re: Passing Gear Linkage [Re: stumpy] #151160
11/16/08 06:54 PM
11/16/08 06:54 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Stumpy, my goal is to help this guy get an answer to his question. I really do understand the indirect or caused-by effect of a tall intake. However, I dont believe that this is the original poster's issue, at least not according to his post. His post says that the linkage actually hits the manifold, and his post is also unclear which manifold. I suspect it is the exhaust. But I do not know that either.
I appologize for getting this post off course.
Re: Passing Gear Linkage [Re: stumpy] #151161
11/16/08 08:13 PM
11/16/08 08:13 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I'm having a hard time seeing the part of the linkage going TO the trans hitting the firewall , it's a linkage ROD that it goes STRAIGHT DOWN ????
What I see is the rod that goes to the CARB not being LONG ENOUGH and the THROTTLE VALVE LINKAGE not operating PROPERLY .
Also stumpy , if you READ the original post the guy says HIGH RISE EXHAUST MANIFOLD , there is NO WAY the TV linage will HIT the EXHAUST manifold unless it's mounted on the outer rail of the VALVE COVER ... The OP is the onethat is confusing the issue along with someone ASSuMEing he meant INTAKE manifold .
Re: Passing Gear Linkage [Re: MoparDonny] #151162
11/16/08 08:48 PM
11/16/08 08:48 PM
Don.
I have a stock intake manifold. The rod that goes straight down is hitting the exhast manifold flange where the exhaust pipe connects, It is not hitting the firewall.
Re: Passing Gear Linkage [Re: moparjo68] #151163
11/16/08 08:54 PM
11/16/08 08:54 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Don.
Do you have the CORRECT exh manifold on the car ???
Re: Passing Gear Linkage [Re: JohnRR] #151164
11/16/08 09:02 PM
11/16/08 09:02 PM
Don.
I have the high rise exhaust manifolds that were manufactured in '68.
Re: Passing Gear Linkage [Re: moparjo68] #151165
11/16/08 09:25 PM
11/16/08 09:25 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Don.
What is the part number on the manifold ?
You either have the wrong manifold or the linkage on incorrectly , if they are the right manifolds the linkage rod will not hit it .
