Carb for a 408 #1511171
10/02/13 12:03 AM
10/02/13 12:03 AM
Iowa
Rodder Offline OP
Rodder  Offline OP
Iowa
Could I hear from you guys with 408 small blocks running a 850 double pumper, what jets sizes work best so it doesn't fowl the plugs and do you use two power valves or one, or none? Thanks
Re: Carb for a 408 [Re: Rodder] #1511172
10/02/13 12:44 AM
10/02/13 12:44 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Bigs 950 stage5+ which uses a proform 850 main body with 1.450 venture. 75/83 1 power valve in the front.
Re: Carb for a 408 [Re: mopar dave] #1511173
10/02/13 01:08 AM
10/02/13 01:08 AM
elmira ny
hp340nos Offline
hp340nos  Offline
elmira ny
i use an aed 850 on my 418 stroker,pump gas.bought through competition wedge racing(todd).it has 79/88 jets,4.5 pv on the primary side,squirters are 37/40,works real well.mike
Re: Carb for a 408 [Re: Rodder] #1511174
10/02/13 05:36 AM
10/02/13 05:36 AM
ont,canada
mopartuner Offline
mopartuner  Offline
ont,canada
I have recently learned that jet sizes depend alot on what carb you run as well as the specs of the motor.I bought one of the new Holley 850 ultra hp carbsand had 88&95 jets and never did get rid of a large stumble.I took it back and got a 850 Q-series Quickfuel carb and had to jet it down and its close with 74&82 jets.No powervalve in the rear and the Quickfuel carb has no stumble and works verry well.
410 pump gas solis flat tappet cam 10.95 so far
Re: Carb for a 408 [Re: mopartuner] #1511175
10/02/13 08:34 AM
10/02/13 08:34 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Holley 950 hp 84 square no power valve, on a 421 small block(4.095x4).
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Carb for a 408 [Re: 1967dartgt] #1511176
10/12/13 05:28 PM
10/12/13 05:28 PM
Hampton Va
gtsdon Offline
gtsdon  Offline
Hampton Va
Pro Systems 850 running 76-86 jets.
