MSD 6AL WIRING #151105
11/14/08 09:43 PM
11/14/08 09:43 PM
Anonymous OP
Anonymous OP
ON AN 68 SUPERBEE WHAT TWO WIRES GO TO THE RED WIRE ON THE MSD BOX. ARE THEY THE ONE'S WHERE THE BALL EST RESISTER USE TO BE.
Re: MSD 6AL WIRING #151106
11/14/08 09:51 PM
11/14/08 09:51 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Yes and please turn off the caps. Yelling is impolite. Also if you keep all the same type of question to one post it's much easier to help you. Thanks
Re: MSD 6AL WIRING #151107
11/14/08 09:52 PM
11/14/08 09:52 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
Yep, one from each side, I think the blue and the brown tie together to it. Not sure of your colors, should be the same. Thats what they are on my Dart. 1 is key on only, the other needs to be hot while cranking it.
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: MSD 6AL WIRING #151108
11/15/08 01:06 AM
11/15/08 01:06 AM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
Maybe this will help.
