Another carb. mounting question? #1511057
10/01/13 09:06 PM
10/01/13 09:06 PM
Cincinnati, Ohio
superbeedave Offline OP
Cincinnati, Ohio
Everybody have a preference on mounting the carburetor on intake with studs and nuts or bolts? Thanks Dave!
Re: Another carb. mounting question? [Re: superbeedave] #1511058
10/01/13 09:39 PM
10/01/13 09:39 PM
Fox River Grove, IL
HotRodRailroader Offline
Fox River Grove, IL
I like studs. But I do take it on and off more frequently. I think if you don't plan on doing that all too often it really doesn't matter.
Re: Another carb. mounting question? [Re: HotRodRailroader] #1511059
10/01/13 10:09 PM
10/01/13 10:09 PM
Cincinnati, Ohio
Cincinnati, Ohio
Thanks! I just hate it when you buy a spacer and they give you studs you will need but they are way too long. After the carb. is bolted on their still 6 or 8 threads above the nut.
Re: Another carb. mounting question? [Re: superbeedave] #1511060
10/02/13 01:47 PM
10/02/13 01:47 PM
I use both, depending on the application and what I have in stock.
Re: Another carb. mounting question? [Re: Cab_Burge] #1511061
10/02/13 09:44 PM
10/02/13 09:44 PM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
I use studs. No screwing up the threads in the manifold from frequent removal of the bolts. Plus everything lines up as you assemble the gaskets and carb. I just think it's a good way to go.
