Mechanics need advice on 05 T&C cooling issue
#1510996
10/01/13 07:58 PM
10/01/13 07:58 PM
Posts: 2,336 Ball Ground, Georgia
Dixie
Guys,
My wife's 05 Town and Country 3.8 V6 has been giving us some issues. I hope you can help point me in the right direction on what to fix. Here's the symptoms:
* Intermittent noise from engine. Sounds like something caught in belts.
* Heat will not work properly. Intermittently doesn't blow hot.
* Slight Antifreeze smell in the cabin.
* Slight interior fogging of the windshield.
* Appears to be using antifreeze, but doesn't leak on driveway.
* Doesn't run hot.
Initially, my thinking is a bad heater core, but the carpet isn't wet that I can tell. Also, thought of a bad thermostat, or heater control valve.
Please let me know your thoughts and any trouble shooting ideas you have.
Thanks, Randy
Re: Mechanics need advice on 05 T&C cooling issue
[Re: IcorkSOAK]
#1511001
10/01/13 08:27 PM
10/01/13 08:27 PM
Posts: 1,395 LAKE TEXOMA
oldman
LAKE TEXOMA
...I have the same issue with the SMELL of coolant ....uses very little ...
But your heads was cracked and the smell was coming from you since you had not washed your rear end for 3 mos.
[Re: oldman]
#1511002
10/01/13 09:10 PM
10/01/13 09:10 PM
Posts: 30,632 Florida STAYcation
IcorkSOAK
Financed his waterbed
Florida STAYcation
3 months ? ..... Is that your typical break from bathing ? ... But when was the last time your cave got flooded?
[Re: stumpy]
#1511003
10/01/13 09:10 PM
10/01/13 09:10 PM
Posts: 75,274 A gulag near you.
JohnRR
A gulag near you.
Heater core and maybe idler pulley.
Heater core most definitely if the windshield is fogging up on the inside.
You don't see a wet spot because the coolant isn't making it out of the heater box ... yet ...
[Re: RapidRobert]
#1511005
10/01/13 10:01 PM
10/01/13 10:01 PM
Posts: 5,003 WI
Dcuda69
WI
X2 Either the heater core is leaking (likely) or a fitting/nipple very close to it (way less likely) that's letting coolant leak into the air ductwork which is why youre seeing the misting. I'd loop off the heater hoses at the eng ASAP then make plans to pull the box or have it done. Winters' a comin
X3 Only time I see windshields fog/missing coolant,etc.
P.S. Doc and Oldman need to take the B.S somewhere else. This member is asking for help....not the BS you guys always get into. You already have a thread dedicated to that crap.
[Re: Dcuda69]
#1511006
10/01/13 10:26 PM
10/01/13 10:26 PM
Dixie
Thanks Guys. I drove it after I made the post and there is definitely a bearing going bad somewhere in the engine compartment. Which one, I don't know just yet. 131K miles on it. Wish I could say it's been relatively trouble free until now, but it hasn't.
