b body 8 3/4 in a body? #151083
11/14/08 09:18 PM
11/14/08 09:18 PM
Maine
K
Kevin D. Offline OP
Kevin D.  Offline OP
K
Maine
Have you ever done this and what do you have to do for wheels? HELP Kevin.
Senior momento!
Re: b body 8 3/4 in a body? [Re: Kevin D.] #151084
11/14/08 09:24 PM
11/14/08 09:24 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
I ran a b body rear complete drum to drum from 66 coronet in a 70 dart
no prob
pas side tire is close but will work
not sure about wider b body rears ..
Re: b body 8 3/4 in a body? [Re: 340dart4spd ] #151085
11/14/08 09:35 PM
11/14/08 09:35 PM
Maine
K
Kevin D. Offline OP
Kevin D.  Offline OP
K
Maine
Cmon now I need some input on this swap any help would be appreciated.Thanks Kevin.
Senior momento!
Re: b body 8 3/4 in a body? [Re: Kevin D.] #151086
11/14/08 09:49 PM
11/14/08 09:49 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
i used stock rallyes 14ich large bolt
Re: b body 8 3/4 in a body? [Re: 340dart4spd ] #151087
11/14/08 09:57 PM
11/14/08 09:57 PM
NE Oklahoma
71valiant Offline
71valiant  Offline
NE Oklahoma
I'm using one in my 71 valiant. I just bolted it up and ran it. Same as any other axles. Some people say to move the spring perches in because they are 1/2 inch to wide. I dident. Its been working fine. You just have to get a rim with alittle more offset.
Re: b body 8 3/4 in a body? [Re: 340dart4spd ] #151088
11/14/08 09:58 PM
11/14/08 09:58 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
An early B rear will work. You'll just have to push the springs a bit to get it to drop in place. Technically the perches need to be moved, but I have driven a few like that forever. Depends on what ya want to do with the car. I use stock steelies, ralleys or road wheels but they get close to the outer lip of the 1/4 and cant handle a wide tire. You can order the offset wheel you'll need though if ya want to tuck it in a bit.
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: b body 8 3/4 in a body? [Re: 70dart360] #151089
11/14/08 10:18 PM
11/14/08 10:18 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
66-67 b-body is the one to use.
I have one for my dart, but had it cut and narrowed to the a-body width. I didn't want to get into the world of strange wheel backspacing.
Re: b body 8 3/4 in a body? [Re: Neil] #151090
11/14/08 11:00 PM
11/14/08 11:00 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I have one in the Duster and it works fine with a 10 wide wheel with 5 inch backspacing. 10.5 M/T slicks.
Re: b body 8 3/4 in a body? [Re: MoparforLife] #151091
11/16/08 10:16 PM
11/16/08 10:16 PM
Midwestern Indiana
duster2 Offline
duster2  Offline
Midwestern Indiana
Really not hard , just have the backspace changed or set on your new set of wheels.....
The Wheel Guy
Re: b body 8 3/4 in a body? [Re: 71valiant] #151092
11/16/08 11:07 PM
11/16/08 11:07 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I did exactly the same thing with my 69 dart. Straight bolt in
Re: b body 8 3/4 in a body? [Re: dave571] #151093
11/17/08 05:33 AM
11/17/08 05:33 AM
SoCal
jake4cars Offline
jake4cars  Offline
SoCal
I did the same thing in my 71 Scamp years ago, bolted right in, no problem, we used rims from a AMC Eagle and they tucked in just fine.
