b body 8 3/4 in a body?
#151083
11/14/08 09:18 PM
11/14/08 09:18 PM
Posts: 13 Maine
Kevin D.
Maine
Have you ever done this and what do you have to do for wheels? HELP Kevin.
Senior momento!
Re: b body 8 3/4 in a body?
[Re: Kevin D.]
#151084
11/14/08 09:24 PM
11/14/08 09:24 PM
340dart4spd
Parts Problem
Parts Problem
I ran a b body rear complete drum to drum from 66 coronet in a 70 dart no prob pas side tire is close but will work
not sure about wider b body rears ..
[Re: 340dart4spd ]
#151085
11/14/08 09:35 PM
11/14/08 09:35 PM
Posts: 13 Maine
Kevin D.
Maine
Cmon now I need some input on this swap any help would be appreciated.Thanks Kevin.
Senior momento!
[Re: Kevin D.]
#151086
11/14/08 09:49 PM
11/14/08 09:49 PM
340dart4spd
Parts Problem
Parts Problem
i used stock rallyes 14ich large bolt
[Re: 340dart4spd ]
#151088
11/14/08 09:58 PM
11/14/08 09:58 PM
Posts: 10,968 Hampton, Ga.
70dart360
Green Meister
Green Meister
Hampton, Ga.
An early B rear will work. You'll just have to push the springs a bit to get it to drop in place. Technically the perches need to be moved, but I have driven a few like that forever. Depends on what ya want to do with the car. I use stock steelies, ralleys or road wheels but they get close to the outer lip of the 1/4 and cant handle a wide tire. You can order the offset wheel you'll need though if ya want to tuck it in a bit.
70 Dart Swinger
72 D-100 440 shortbed
76 Pinto, 68k 21mpg!
[Re: 71valiant]
#151092
11/16/08 11:07 PM
11/16/08 11:07 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
I'm using one in my 71 valiant. I just bolted it up and ran it. Same as any other axles. Some people say to move the spring perches in because they are 1/2 inch to wide. I dident. Its been working fine. You just have to get a rim with alittle more offset.
I did exactly the same thing with my 69 dart. Straight bolt in
[Re: dave571]
#151093
11/17/08 05:33 AM
11/17/08 05:33 AM
Posts: 1,973 SoCal
jake4cars
SoCal
I did the same thing in my 71 Scamp years ago, bolted right in, no problem, we used rims from a AMC Eagle and they tucked in just fine.
