Re: Stamps/Stencils for diff. part marking
[Re: 1ol74charger4me]
#1510841
10/27/13 11:44 AM
10/27/13 11:44 AM
Posts: 244 Il
1ol74charger4me
Il
Updating the list.
Housing, "9-14U". Pig, "9-14". Housing, "5-12Z". Pig, ? Housing, "2-16X". Pig, ? SPD 2/26. Housing, "...1L". Pig, "10-23". Hamtramck. SPD 11/8/68. Housing, "101G". Pig, ? Housing, "J128". Pig, ? Housing, "19U". Pig, ? should be 190, I had went over it with paint pen to get a size picture of it, pig was a 67 and no markings Final cleaned the rear and found it was in fact a U. I think there is a correlation between the housing date and the pig date. Maybe same date or close. Found this while cleaning the housing also. Big surpise. B body+J code engine ?
#1510845
03/17/14 02:36 AM
03/17/14 02:36 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Here's paint daubs and marks on a 1969 Barracuda 8-3/4 axle with 3.23:1, non Sure Grip, made at Hamtramck November 1968.
White paint daub on yoke:
[Re: kentj340]
#1510846
03/17/14 02:40 AM
03/17/14 02:40 AM
kentj340
Cut and Shoot, TX
Assembly date of the carrier only, 10/23/68.
[Re: kentj340]
#1510847
03/17/14 02:43 AM
03/17/14 02:43 AM
kentj340
Cut and Shoot, TX
This paint is rust stained but is actually white. There are bars above and below the 23. The SPD of the car was B08, November 8. The actual build date was several days later, because the car arrived at the Houston dealer on November 27. A good chemical rust remover will leave the paint, so I can keep this original stencil as it is under some RPM wax.
[Re: kentj340]
#1510848
03/17/14 03:03 AM
03/17/14 03:03 AM
kentj340
Cut and Shoot, TX
The yellow unit assembly date, L1xxx, is on the bottom of the driver side. The last three numbers of the assembly part number, 565, are seen just above on the front of the housing. The yellow 565 is upside down when the axle is on the car.
[Re: kentj340]
#1510849
03/17/14 03:13 AM
03/17/14 03:13 AM
kentj340
Cut and Shoot, TX
The yellow unit assembly date, according to others, is usually the same date as the carrier date or one or two days after. Nobody seems to know what the alpha means. This might be L10 23 or L10 24? Looks like the 1 and L are upside down to each other?
[Re: kentj340]
#1510851
03/17/14 03:40 AM
03/17/14 03:40 AM
kentj340
Cut and Shoot, TX
Here's the upside down yellow assembly number 565 with the driver side spring perch below right. This is the same number on my broadcast sheet under AXLE. AFAIK the only places you can get this part number are from the axle, from the build sheet, or copy somebody else's car that has the exact same axle (year, size, ratio, w or w/o Sure Grip, brakes) in the same kind of car with the same engine and transmission. Note there is more paint at the edges of the numbers. There is an intentional or unintentional bar under a 5.
[Re: kentj340]
#1510852
03/17/14 03:46 AM
03/17/14 03:46 AM
kentj340
Cut and Shoot, TX
Yellow paint daub on front passenger side.
[Re: kentj340]
#1510853
03/17/14 03:51 AM
03/17/14 03:51 AM
kentj340
Cut and Shoot, TX
These photos don't show it, but there was spray paint overspray inside the housing.
[Re: kentj340]
#1510854
03/17/14 04:04 AM
03/17/14 04:04 AM
kentj340
Cut and Shoot, TX
Almost gone, but here's another round yellow paint daub of the same size at the front of the passenger side spring perch. Couldn't find one on the driver side.
[Re: kentj340]
#1510855
03/17/14 04:13 AM
03/17/14 04:13 AM
kentj340
Cut and Shoot, TX
My yellow A was done by a pro and looks better than yours. The A is right side up when installed. A white paint stick X is above.
[Re: kentj340]
#1510856
03/17/14 04:22 AM
03/17/14 04:22 AM
kentj340
Cut and Shoot, TX
Here's the white X above the A. This mark was made with a paint stick, not a lumber crayon.
[Re: kentj340]
#1510858
03/17/14 05:22 AM
03/17/14 05:22 AM
kentj340
Cut and Shoot, TX
Last one for this 69 Barracuda 8-3/4, 3.23, non Sure Grip. A scrawled 8 on the pig. There's a small amount of a different shade of blue splashed on the top side of the pig. I'll keep the marks on the pig as they are. The housing will get repainted semi gloss black after the rust pits are filled in, so the housing will get re-daubed.
