msd 6al run's while cranking #151074
11/14/08 08:27 PM
11/14/08 08:27 PM
Anonymous OP
Anonymous OP
I put msd 6al along with msd distributor in an 68 superbee. I'am trying to start car but all it will do is run while cranking let off the key car die's.PLEASE CAN ANYONE HELP.
Re: msd 6al run's while cranking #151075
11/14/08 08:42 PM
11/14/08 08:42 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I would bet that you don't have power to the small red wire when the key is on, only in crank.
Re: msd 6al run's while cranking [Re: slantzilla] #151076
11/14/08 08:50 PM
11/14/08 08:50 PM
St. Charles, MO
wingman Online happy
Uncreative Title
wingman  Online Happy
Uncreative Title
St. Charles, MO
Yes, you have it wired improperly.
Mopars have one ignition wire that is hot while the key is in the "start" postion, but cold in the "run" postion.
There is another wire in the same harness that behaves exactly the opposite--cold in "start" but hot in "run".
You need to find both leads and run them both to the small red wire on the 6AL. That way, it will be energized both in "start" and "run".
-Mike
(P.S. Also, you can do away with your ballast resistor--you don't need it with the MSD)
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: msd 6al run's while cranking [Re: wingman] #151077
11/14/08 09:30 PM
11/14/08 09:30 PM
Anonymous OP
Anonymous OP
THANK YOU for your advice it's what I was hoping it would be. Tomorrow is another day I will look for the other wire any idea where to look first is it up where the ballest resister use to be. THANK YOU
