Front End Question
#1510035
09/30/13 02:26 PM
09/30/13 02:26 PM
Posts: 474 Alberta, Canada
451Guy
Alberta, Canada
I was wondering what you guys are doing to free up/ loosen you torsion bar front ends.
Any suggestions would be appreciated.
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T Best ET 11.39 @ 118.11
Re: Front End Question
[Re: 451Guy]
#1510036
09/30/13 09:28 PM
09/30/13 09:28 PM
Posts: 43,251 Bend,OR USA
Cab_Burge
Remove the stock or any sway bar, use really good front drag shocks, change the torsion bars over to a set 6 cylinder non air condition car bars, lower the front ride hieght as far as possible, including maybe trimming and shortening the lower control arm bumper. Remove any unneeded front end weight, fibregals front bumper, hood, aluminum radiator, aluinum water pump and housing, aluminum brake master cylinder, remove heater and under coating and so on I'm sure there are a lot more than I can think of at this time, hopefully others will chime in Lots of ways to help the old girl pitch rotate
