made some headway on my 60'
#1509866
09/30/13 09:53 AM
09/30/13 09:53 AM
Posts: 8,033 Mt Morris Michigan
mopar dave
Mt Morris Michigan
went to a different track yesterday(midmichigandragway) and made some improvements on my 60's. only difference to car was a new ICE ignition box & coil. best 60 to date was a 1.51 with the cal-tracs. first 2 back to back passes 1.499,1.468. bars in lower hole. john calvert says aslong as your not spinning going to the upper hole will not improve 60'. I put the bars in the upper hole and 1.456,1.473,1.468. shocks on 7. shock on 9 1.488. so what do ya think? upper hole or lower hole? best of the day was [Email]10.47@128.9[/Email]
Re: made some headway on my 60'
[Re: mopar dave]
#1509867
09/30/13 11:12 AM
09/30/13 11:12 AM
Posts: 5,160 Texas
dannysbee
Texas
Make some shock changes on the lower hole then draw a conclusion.
Getting old just means you were smarter than some and luckier than others.
[Re: mopar dave]
#1509870
09/30/13 12:55 PM
09/30/13 12:55 PM
Posts: 1,178 Indy
FlyFish
Indy
Nice Dave! I also made improvements on mine as well this weekend, but mine is due to a fresh transmission, 1.47 60', 6.81 1/8. My Caltracs are still on the lower hole, 1 flat driver side, 2 flats passenger side, shocks on 6.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: mopar dave]
#1509872
09/30/13 02:12 PM
09/30/13 02:12 PM
Posts: 5,160 Texas
dannysbee
Texas
I would log 10 passes in the upper and lower hole at the best shock settings & go with the best average.
[Re: mopar dave]
#1509874
09/30/13 03:20 PM
09/30/13 03:20 PM
Posts: 5,160 Texas
dannysbee
Texas
Your mph was down 3mph. Air was probably the hp difference. Et would have been worse if your 60 had not picked up.
[Re: mopar dave]
#1509876
10/01/13 09:47 AM
10/01/13 09:47 AM
BradH
... john calvert says aslong as your not spinning going to the upper hole will not improve 60'.
I'd take that as a generality and tune for what works best for your car. I've never tried the upper hole position on my Challenger, but it's nose-heavy compared to your car and IMO the lower position helps w/ the weight distribution.
[Re: ajcasini]
#1509881
10/01/13 11:26 AM
10/01/13 11:26 AM
Posts: 2,703 Mohnton, Pa
DodgeCharger
Mohnton, Pa
Guys I fought this 60' battle with my roadrunner last year. Car was 60' 1.44-1.48 wih caltracs and rancho 9way shocks. Car would begin to lift just as some are describing then give a wiggle and set the tires down 10-15' off the line. Was causing et variation on the top end from 10.38-10.45. Changed rear shocks to qa1 double adjustable. First weekend out car was a different animal on the line. 1.37-1.38 60' time et 10.30-10.32. The best improvement was consistency though. 60' stayed glued in thr 1.37-1.38 range thus et was much more consistent. Once you get to a certain power level the rancho/Calvert 9way shocks just aren't up to the task.
This is what worked forme.
Can you post a link or part number for the shocks your talking about? What do they cost?
