Wheel Cylinder Rebuild Sevice #1509674
09/29/13 07:00 PM
09/29/13 07:00 PM
Dreaming of the 808
AZ_A12_BEE Offline OP
Dreaming of the 808
Other than White Post Restorations is there anybody else than can rebuild the brake wheels cylinders and reline the brake shoes on my 37?
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: Wheel Cylinder Rebuild Sevice [Re: AZ_A12_BEE] #1509675
09/29/13 07:07 PM
09/29/13 07:07 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't be the exception.
Re: Wheel Cylinder Rebuild Sevice [Re: Supercuda] #1509676
09/29/13 07:19 PM
09/29/13 07:19 PM
Dreaming of the 808
Dreaming of the 808
http://www.oldmoparts.com/parts-service-brakes.aspx
If you want new
I don't see a reason to spend that kind of money on new when I can get my parts rebuilt
Re: Wheel Cylinder Rebuild Sevice [Re: AZ_A12_BEE] #1509677
09/29/13 08:43 PM
09/29/13 08:43 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
so have you considered doing it? It's really not that difficult, besides you can make a mess honing it!
Re: Wheel Cylinder Rebuild Sevice [Re: AZ_A12_BEE] #1509678
09/29/13 08:56 PM
09/29/13 08:56 PM
Depending on where you live there should be a brake reliner company in one of the larger citys near you. I would call them and see if they willreline your shoes, give them the width and length of the existing linings and see what they say As far as the cylinders I would take one of them apart and see what size the inner rubber seals and pistons are and what condition the pistons and cylinders are in and go from there. I have had to have some of the hard to find 1966 to 1969 B body Kelsey Hayes 4 piston Mopar style calipers honed out and had a stainless steel sleeve installed in them to make them usuable, not cheap but it kept the car stock appearing and driveable
Re: Wheel Cylinder Rebuild Sevice [Re: Cab_Burge] #1509679
09/29/13 09:02 PM
09/29/13 09:02 PM
Dreaming of the 808
Dreaming of the 808
Pistons are froze, might have to buy new ones, look pretty bad
Re: Wheel Cylinder Rebuild Sevice [Re: AZ_A12_BEE] #1509680
10/01/13 12:42 PM
10/01/13 12:42 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
Lots of truck supply places can reline brakes pretty cheap
Re: Wheel Cylinder Rebuild Sevice [Re: SSAAHemiFan] #1509681
10/02/13 01:18 AM
10/02/13 01:18 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Several links here for brass sleeving of cylinders.
http://www.brakecylinder.com/index.htm
Re: Wheel Cylinder Rebuild Sevice [Re: kentj340] #1509682
10/03/13 01:27 AM
10/03/13 01:27 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Did you see the photo of the '36 in the gallery here?
http://www.brakecylinder.com/Gallery.htm
Too bad he retired. Perusing the web site shows he was very knowledgeable about brake cylinders. Fortunately I got all 5 of my cylinders brass sleeved by him a couple of years ago. See the FAQs about stuck cylinders.
He also discusses tube seats under FAQs, which applies to the muscle car years.
Re: Wheel Cylinder Rebuild Sevice [Re: kentj340] #1509683
10/03/13 09:12 AM
10/03/13 09:12 AM
MD
floyd Online content
floyd  Online Content
MD
Check these Guys. I used them to rebuild a master cylinder and they are really good to work with.
http://brakeplace.com/
Click the "Machine Shop" tab.
Brake & Equipment Warehouse
455 Harrison Street NE
Minneapolis, MN 55413
Phone: 612-378-3141 Toll Free: 1-800-233-4053
