what color is the k-frame painted #1509483
09/29/13 11:46 AM
09/29/13 11:46 AM
South Lyon MI
sleddinfool Offline OP
South Lyon MI
1971 plymouth gtx.. Thinking I am painting it chassis black.. would the be correct? Thanks Kevin
71 gtx.....
Re: what color is the k-frame painted [Re: sleddinfool] #1509484
09/29/13 11:48 AM
09/29/13 11:48 AM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
Black and rust.
Re: what color is the k-frame painted [Re: sleddinfool] #1509485
09/29/13 11:48 AM
09/29/13 11:48 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
That's what I used. Has held up well.
Re: what color is the k-frame painted [Re: GomangoCuda] #1509486
09/29/13 11:50 AM
09/29/13 11:50 AM
Cincinnati, Ohio
Cincinnati, Ohio
Black and rust.
Can't argue with that...
Re: what color is the k-frame painted [Re: Challenger 1] #1509487
09/29/13 12:01 PM
09/29/13 12:01 PM
South Lyon MI
South Lyon MI
Thank-you and thanks you...Now,I should have asked this also..I saw somewhere that thelower control arms are not painted but covered in cosmoline? Who sells that stuff? Kevin
71 gtx.....
Re: what color is the k-frame painted [Re: sleddinfool] #1509488
09/29/13 12:05 PM
09/29/13 12:05 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Krylon Battery Protector works best!
Admiration For Multiple Carburetor Vehicles...
Re: what color is the k-frame painted [Re: Stewpar] #1509489
09/29/13 12:14 PM
09/29/13 12:14 PM
Cincinnati, Ohio
Cincinnati, Ohio
Or I used some gold paint, mine are not going to rust.
Re: what color is the k-frame painted [Re: Challenger 1] #1509490
09/29/13 12:36 PM
09/29/13 12:36 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
The real deal is still available and is the only true "Correct" coating.
Cosmoline
Rust Veto 342 is the stuff you need
Re: what color is the k-frame painted [Re: ScottSmith_Harms] #1509491
09/29/13 07:54 PM
09/29/13 07:54 PM
South Lyon MI
South Lyon MI
Sweet, Thanks again.. Scott, I was going to order the rust veto stuff.. How much do I need? LOL.. How much of the underneath of the car used this besides the frt control arms rear axle? Springs? Hangers, shackles.. I want to get this car close to original..That way if I ever sell it, whoever ends up with it will not have to do as much. I am swaying from stock on the engine-trans, but am saving the originals also. Kevin
71 gtx.....
Re: what color is the k-frame painted [Re: sleddinfool] #1509492
09/29/13 10:13 PM
09/29/13 10:13 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I bought a gallon to do my LCAs, mainly so I'd have enough to fill a container deep enough to dip them in (which I custom made from plastic sheet and duct tape to allow the container to be as small as possible). Most cars didn't have obvious cosmoline on many other parts so the LCAs will likely be your biggest use for it.
Re: what color is the k-frame painted [Re: ScottSmith_Harms] #1509493
09/29/13 11:48 PM
09/29/13 11:48 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
Which Cosmoline? I've seen a transparent dark brown to an opaque very light beige.
Re: what color is the k-frame painted [Re: 375inStroke] #1509494
09/30/13 11:47 AM
09/30/13 11:47 AM
imperial mo.
stickman Offline
stickman  Offline
imperial mo.
What chassis black have you guys used with success and should it be more of a stain finish? Thanks
YOU CAN`T RUN WITH THE BIG DOGS IF YOU NEVER LEAVE THE PORCH.
EB5 70 U Code RT/SE Shaker Challenger
Re: what color is the k-frame painted [Re: stickman] #1509495
09/30/13 12:04 PM
09/30/13 12:04 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Stewpar-
Is it Krylon 1307? The description says clear. Mike
Re: what color is the k-frame painted [Re: stickman] #1509496
09/30/13 12:08 PM
09/30/13 12:08 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
No they used cheap gloss black. It faded easily and looks less glossy than our newer better paints. But it was not satin.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: what color is the k-frame painted [Re: MOPARMIKE69] #1509497
09/30/13 12:14 PM
09/30/13 12:14 PM
South Lyon MI
South Lyon MI
I stopped and looked for both the krylon and the cosmoline at a couple auto parts stores. No-go.. I can find both online but don't want to buy ten times more then I need, lol. I have enough junk laying around.. Kevin
71 gtx.....
Re: what color is the k-frame painted [Re: sleddinfool] #1509498
09/30/13 01:54 PM
09/30/13 01:54 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
You can buy Cosmoline direct/mail order from the site I linked above, about $100.00 a gallon. As far as black goes for the k-member, as mentioned, cheap gloss black was used that usually blushed a bit making it appear less glossy than modern better quality paints.
Re: what color is the k-frame painted [Re: sleddinfool] #1509499
09/30/13 01:56 PM
09/30/13 01:56 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
I use Krylon rust tough semi-flat black. Holds up well.
Re: what color is the k-frame painted [Re: nomore65BelvJim] #1509500
09/30/13 02:27 PM
09/30/13 02:27 PM
South Lyon MI
South Lyon MI
65Belvjim... That is exactly what I bought yesterday-- Thanks. Kevin
71 gtx.....
Re: what color is the k-frame painted [Re: sleddinfool] #1509501
10/01/13 01:14 PM
10/01/13 01:14 PM
None
71rm23 Offline
71rm23  Offline
None
I powder coated my K for my 71 RR. Resto Rick and Dayclona has cosmoline
Re: what color is the k-frame painted [Re: MOPARMIKE69] #1509502
10/02/13 12:31 PM
10/02/13 12:31 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
From the tech archives;
https://board.moparts.org/ubbthreads/show...e=0#Post7406447
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
