Anyone here ever have their pistons machined? #1509441
09/29/13 05:26 AM
09/29/13 05:26 AM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
Still dealing with detonation with the 440/493. I'm considering many things to stop it.
I spoke with Dwayne Porter awhile back and he suggested milling my pistons .040 on the chamber side to reduce compression.
Has anyone here had this done before? Any ideas on the cost?
Re: Anyone here ever have their pistons machined? [Re: Kern Dog] #1509442
09/29/13 10:51 AM
09/29/13 10:51 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Increase the head gasket thickness would be the easy and cheaper way of decreasing compression.What is your piston to head clearence or piston to deck height now?
Re: Anyone here ever have their pistons machined? [Re: Kern Dog] #1509443
09/29/13 11:08 AM
09/29/13 11:08 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Guess you did not like my previous suggestion to get quench and lower CR all in one. Don't even need to pull the motor.
Re: Anyone here ever have their pistons machined? [Re: BSB67] #1509444
09/29/13 01:39 PM
09/29/13 01:39 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
A thicker head gasket will lower compression, true. Don't know how much piston to head clearance you have. If you have a good PTH clearance like .050" or less. The easiest simple way is head gasket.
I never go the easy route as it usually does not give the most benefit. To cut a dish in your piston you need to have the material to do so and still have enough thickness. If you do have enough material that is the way to go but, be aware this will change your balance numbers.
If your head is open chamber design then the thicker gasket will be the way to go.
Leon
Re: Anyone here ever have their pistons machined? [Re: BSB67] #1509445
09/29/13 02:22 PM
09/29/13 02:22 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
I don't want to appear ungrateful to anyones suggestions, it just worries me to go higher in compression to gain quench.
Re: Anyone here ever have their pistons machined? [Re: Kern Dog] #1509446
09/29/13 02:25 PM
09/29/13 02:25 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I don't know your combo. That being said if you now have .035-.045" quench currently, adding head gasket thickness to reduce compression may make detonation worse. If you have no quench now I would definitely go with a thicker gasket.
Doug
Re: Anyone here ever have their pistons machined? [Re: dvw] #1509447
09/29/13 03:20 PM
09/29/13 03:20 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Doug
The problem is he doesn't have good quench and wanted to make it worse with yet a thicker gasket to lower compression.
Re: Anyone here ever have their pistons machined? [Re: Kern Dog] #1509448
09/29/13 03:44 PM
09/29/13 03:44 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Has any chamber work been done? You could add a few ccs by blending and unshrouding. Something i would do anyway .
Re: Anyone here ever have their pistons machined? [Re: Kern Dog] #1509449
09/29/13 04:23 PM
09/29/13 04:23 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
That is not what I said.
This is what I said:
"Take the heads off and have someone with a cnc program (like MCH) cut the chambers to the desired cc's, and put it back together with the 0.027 gaskets."
You want 88 cc, they will cut the chamber to 88 cc., not mill the head.
Re: Anyone here ever have their pistons machined? [Re: JohnRR] #1509450
09/29/13 07:14 PM
09/29/13 07:14 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Doug
If the quench is poor already adding head gasket thickness won't hurt it. Am I correct in assuming this is an open chamber style head?
Doug
Re: Anyone here ever have their pistons machined? [Re: dvw] #1509451
09/30/13 01:19 AM
09/30/13 01:19 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Doug
Doug
No it's closed chamber wit hthe piston not at zero . He already put in a thicker gasket , I think .051, so he has .070ish no quench , and changed the cam ... still pings ...
Re: Anyone here ever have their pistons machined? [Re: JohnRR] #1509452
09/30/13 07:25 AM
09/30/13 07:25 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
So closed chamber with piston in the hole approximately .020". Using a .020" gasket ( how thick are the thinnest shim availible ?) would give .040" quench. Iron or aluminum head? I've had small blocks have less detonation with quench at 12-1 than w/o at 10.5-1. Would it work in this case? it would only cost the gasket set.
Doug
Re: Anyone here ever have their pistons machined? [Re: dvw] #1509453
09/30/13 07:57 AM
09/30/13 07:57 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Doug
Doug he has numerous threads on this over the past year or so, I didn't keep a scorecard . Pretty sure the original combo had the .020 piston depth and .021 shim gasket with .509 MP cam and it pinged , it has spiraled out of control since ...
Re: Anyone here ever have their pistons machined? [Re: JohnRR] #1509454
09/30/13 08:56 AM
09/30/13 08:56 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Doug
Maybe he should look for other issues:
Timing not accurate,bad marks,box, dist and etc.
Too hot of plug.
poor fuel or lean condition
Cylinder head temperture
Oil detonating in cylinder..
If some of the information mentioned is correct with his clearences correct timing should cure the issue provided he doesn't have other issues.
Re: Anyone here ever have their pistons machined? [Re: B G Racing] #1509455
09/30/13 11:10 AM
09/30/13 11:10 AM
dogdays Offline
dogdays  Offline
This subject has been beaten to death on the Q&A page.
R.
Re: Anyone here ever have their pistons machined? [Re: dogdays] #1509456
09/30/13 05:01 PM
09/30/13 05:01 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
R.
which is why it's moved to the race section ???
Re: Anyone here ever have their pistons machined? [Re: JohnRR] #1509457
09/30/13 05:43 PM
09/30/13 05:43 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Put a bigger cam in it
To answer the original question I've never had a set of pistons machined but its been done many times before
Re: Anyone here ever have their pistons machined? [Re: dogdays] #1509458
09/30/13 05:52 PM
09/30/13 05:52 PM
California
mickm Offline
mickm  Offline
California
R.
yes, but he's looking for answers and now has moved it from a more general thread to a more specific one.
he has done many, many things to try and take care of this problem, and it's still haunting him, so he's just trying to get as much info as possible before making the next decision.
Re: Anyone here ever have their pistons machined? [Re: mickm] #1509459
09/30/13 10:40 PM
09/30/13 10:40 PM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
Also it's now the "Unlawfl's Race & Engine Tech" section, so it belongs here.
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: Anyone here ever have their pistons machined? [Re: GTX MATT] #1509460
09/30/13 10:41 PM
09/30/13 10:41 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
he did , it didn't make it any better
