Page 3 of 4 1 2 3 4
Re: Please rate time slip for street car [Re: dfsmopars] #1509319
09/30/13 08:14 PM
09/30/13 08:14 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
You are getting a lot of conflicting info here. Some say gear and converter, others say "more power".
Your time slip actually points to one on these as the place to focus if you want better ets and mph. Quite simply, it is not the gear/converter. Unless of course there is something wrong with the converter that it is eating hp (possible).
When you look at the generally accepted formula for dissecting quarter mile data, it shows that if your had a perfect racing suspension (this includes gear and converter) you best possible et is about 13.9.
These empirically derived formula are pretty reflective of reality. However, certain conditions can alter the conclusions drawn. These conditions include motor related problems that cause the motor to be down on power at the end of the track (i.e. skewing the et/60" times relative to the mph), examples include ignition cut out, or fuel starvation. When power, or mph seem down, always check that you don't have a fuel delivery problem.
IIRC, your post asked what we thought about your quarter mile performance relative to what you have, and not necessarily what is need to go quicker/faster. I still maintain that you are not that far off and hold to my previous suggestions to make what you have perform better. My sense from your post was."..what should it run with what I have", not "...what could it run if I throw a bunch of money/changes at it".
Also, like someone else said, wind and atmospheric conditions can have a very measurable effect on performance.
Tell us what day and track you were at.
Re: Please rate time slip for street car [Re: dfsmopars] #1509320
09/30/13 08:29 PM
09/30/13 08:29 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
You can also post this in the race section. Lots of street/strip guys on there with tons of knowledge.
Re: Please rate time slip for street car [Re: dustergirl340] #1509321
09/30/13 09:03 PM
09/30/13 09:03 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
Besides getting the actual weight of your car, finding out the DA at the track will go a long way to finding out where you are at for a baseline.
This website works well, just punch in your track, date, and time of run from your timeslip:
http://www.dragtimes.com/da-density-altitude-calculator.php
Re: Please rate time slip for street car [Re: 67Satty] #1509322
09/30/13 11:56 PM
09/30/13 11:56 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Which bushing do you have on the distributor? If it's not the black one, install that and reset your timing and carb setting.
If you slapped the distributor in as delivered, it's got a garbage tune on it. Also change the spring from teh garage door openers that are on it to a light silver and blue spring.
It's missing a bunch of power with the doggy MPH and is a soggy banana done low is my bet.
If that thing is tuned with proper fuel delivery and running right it should go low 13's easily. A 360, xe268H LD340, 350ish hp on a dyno in a 3300# a body ran over 104 in vegas in bad air. OP has got more cam from a lift perspective and better heads.
Re: Please rate time slip for street car [Re: BSB67] #1509323
10/01/13 07:41 AM
10/01/13 07:41 AM
Kentucky
dfsmopars Offline OP
Kentucky
The day was sunnny and at the time of the run it was about 78° and the RH was pretty low at about 60%. There was a slight cross wind coming across from right to left.
Seems the car has something left on the table as it is built and it'd be nice to find the optimum set up with the equipment currently installed then move on to better things down the road. Gears and carb are definitely in its future but not right now. Life demands more thoughtful spending these days.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: Please rate time slip for street car [Re: dfsmopars] #1509324
10/01/13 09:38 AM
10/01/13 09:38 AM
Fort Collins, Colorado
CoDart Offline
CoDart  Offline
Heres my setup which is very similar to yours:
3450lb Dart(with me)
Magnum 360 with 9.5 compression, RHS indy heads, 228/232 .540 lift cam, 904 3500rpm stall, 3.91 gears,275/60/15 et radial tires. 85 octane gas. Ran a 13.8@98mph(1.91 60ft). Keep in mind this was at 5500ft above sea level and was 8400 DA that day, this would equal out to a high 12 second car at sea level. With your set up a larger carb would help out. I went from a 600cfm edelbrock to a 950DP holley and it went from 95mph to 98mph instantly without no tuning or changes on anything else. That change is about 25-30hp gain by a simple carb swap. My timing is set at 38* advanced. With a few changes to your combo you will be seeing low 14s high 13s
Re: Please rate time slip for street car [Re: dfsmopars] #1509325
10/01/13 01:33 PM
10/01/13 01:33 PM
Someplace you aren't
SomeCarGuy Online content
SomeCarGuy  Online Content
The 60 foot is good to get into the 13's with. The ET and MPH are indicating the engine is not producing at the end of the run. While the ignition might not be perfect, it is more likely fuel that needs attention.
I want my fair share
Re: Please rate time slip for street car [Re: dfsmopars] #1509326
10/01/13 03:10 PM
10/01/13 03:10 PM
Kentucky
Kentucky
With the swell of information now it's time to play more with the dist and timing. Sounds like the car is not too far off. Appears all the information needed has been posted so I'll print it out and work through it.
Perhaps the most beneficial trial is a much different carb. Who has a 750 DP laying around?
Re: Please rate time slip for street car [Re: dfsmopars] #1509327
10/01/13 04:57 PM
10/01/13 04:57 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Throwing street use out the window?
A DP is the last carb you need on the street. It'll suck fuel like no tomorrow. Every time the pedal moves they shoot fuel on both sides.
You should be able to tune a single pump carb to perform perfectly on that kind of engine. The second pump shooter is best saved for the bracket guys.
- Stu Harmon
Re: Please rate time slip for street car [Re: feets] #1509328
10/01/13 05:10 PM
10/01/13 05:10 PM
Renton Washington
Triple Threat Offline
Renton Washington
Wrong... The linkage is still progressive. Stay out of the secondaries and you'll be fine. I daily drove my dart for years with the 340 and a 4150 750. The car ran 12.30@107 and would get 15MPG @3600# with 3.91 gears and 26" tire. BUT, I dont think the carb is the issue, its probably multitude of things making this a mismatched/ underperforming combo.
The OP needs to weigh that thing before we get into too much detail. Yes MPH seems low, but that car could be pretty heavy which would explain most of that.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Please rate time slip for street car [Re: Triple Threat] #1509329
10/01/13 05:25 PM
10/01/13 05:25 PM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
I daily drove my dart for years with the 340 and a 4150 750. The car ran 12.30 @107 and would get 15MPG @3600# with 3.91 gears and 26" tire.
Mine runs 12.40's at 107 with a 340, same carb, same gears, and 28" tall tire and gets 14MPG.
Re: Please rate time slip for street car [Re: Triple Threat] #1509330
10/01/13 05:41 PM
10/01/13 05:41 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Touch the secondaries (easy to do when entering the highway and such) and you're sucking down fuel.
Again, the DP carbs are best left to racers. A *GASP* vacuum secondary carb would be more than enough for this setup.
- Stu Harmon
Re: Please rate time slip for street car [Re: dustergirl340] #1509331
10/01/13 05:49 PM
10/01/13 05:49 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Mine had a twin turbocharged blow through carbed 440 with 3.23 gears and a 28" tire. It got 17 mpg. Adding the EFI maintained the mpg but added drivability.
It's all about the combo.
- Stu Harmon
Re: Please rate time slip for street car [Re: feets] #1509332
10/01/13 06:00 PM
10/01/13 06:00 PM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
Mine has great driveabilty on the street, and I'm perfectly fine with 14MPG. It's a toy, not a daily driver.
Re: Please rate time slip for street car [Re: Triple Threat] #1509333
10/01/13 06:01 PM
10/01/13 06:01 PM
RobX4406 Offline
RobX4406  Offline
Wrong... The linkage is still progressive. Stay out of the secondaries and you'll be fine. I daily drove my dart for years with the 340 and a 4150 750. The car ran [Email]12.30@107[/Email] and would get 15MPG @3600# with 3.91 gears and 26" tire. BUT, I dont think the carb is the issue, its probably multitude of things making this a mismatched/ underperforming combo.
BINGO!
Drive a DP with any sense of what you are doing and mileage is not an issue. If you have a lead foot and always mat it from a light, mileage will stink. It's all in the right foot.
13.60-104, 20 mpg on the highway with a 4779 750dp. It got 14-15 around town...
My guess, OP needs to fix the initial timing, bushing, springs FIRST! Don't do anything else until you get that sorted out.
Vacuum carbs easily give up 2 tenths at the track compared to a DP.
Re: Please rate time slip for street car [Re: dfsmopars] #1509334
10/01/13 06:55 PM
10/01/13 06:55 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Still helpful to give us the track and date, and car weight when you get it.
Re: Please rate time slip for street car [Re: RobX4406] #1509335
10/01/13 06:56 PM
10/01/13 06:56 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
I think we also need to know what the DA was at the time of the run. If you tell me the track, date, and time, I'll punch it into the website I posted above. 5000 DA? 0 DA? We don't know, makes a big difference.
Re: Please rate time slip for street car [Re: 67Satty] #1509336
10/01/13 06:57 PM
10/01/13 06:57 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
You mean it'd make a difference if he was running at Pikes Peak?
- Stu Harmon
Re: Please rate time slip for street car [Re: BSB67] #1509337
10/01/13 09:58 PM
10/01/13 09:58 PM
Kentucky
Kentucky
I'll get the weight this week. The run was on 9/28/13 at Mountainpark Dragway in Clay City, KY at about 4:00 PM.
Keep in mind the dist is fully electronic. No weights or manual adjustments. Everything is controlled by pods.
Re: Please rate time slip for street car [Re: dfsmopars] #1509338
10/01/13 10:07 PM
10/01/13 10:07 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
OK, cool. Your DA at 4 pm that day was 1919 feet.
Page 3 of 4 1 2 3 4
