Page 1 of 4 1 2 3 4
Please rate time slip for street car #1509279
09/28/13 09:42 PM
09/28/13 09:42 PM
Kentucky
dfsmopars Offline OP
Kentucky
Not that I really feel I have to say this but please be honest but rate this time slip.
Car
'72 Charger, full interior, 360 Magnum (.02 over), full roller, .544 lift 218/228 Hughes cam, 650 Carter on Air Gap intake, RHS iron heads, Hooker SB headers, timing at 35° advanced, MSD Pro Billet distributor (no box), 2.5" exhaust, AT w/2500 Hughes stall, 3.55 gears, 28.5 x 12 tires.
Time Slip
60'- 2.02
E.T.- 14.20
MPH- 93.5
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: Please rate time slip for street car [Re: dfsmopars] #1509280
09/28/13 09:49 PM
09/28/13 09:49 PM
michigan woods
imfixinmopars426 Offline
michigan woods
heavy car to get moving with SB...gears,and converter hurts 60 ft,BUT do you want a race car,or a nice street car?? sounds like a nice driver...how does it feel to YOU??
Re: Please rate time slip for street car [Re: dfsmopars] #1509281
09/28/13 09:53 PM
09/28/13 09:53 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Needs suspension work!!!
Re: Please rate time slip for street car [Re: moparpollack] #1509282
09/28/13 10:03 PM
09/28/13 10:03 PM
Kirkland, Washington
Pacnorthcuda Offline
Maybe, but that's not the big issue. The big problem is the 93.5 trap. A 2.02 60 can produce ETs in the low to mid 13's pretty easy, IF the top end is there.
OP: you're not creating the HP you should. It could be the tune, or that carter carb, but something is holding back on the top end.
Re: Please rate time slip for street car [Re: Pacnorthcuda] #1509283
09/28/13 10:06 PM
09/28/13 10:06 PM
85086
Lil Herman
Lil Herman
85086
Just reread the post needs fuel work and a better carb!
Re: Please rate time slip for street car [Re: moparpollack] #1509284
09/28/13 10:19 PM
09/28/13 10:19 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Ignition may need refining too.
35 total is a pretty useless number. What's the split if it has an advance curve.
Definitely lacking MPH. Carb... yuk!
Re: Please rate time slip for street car [Re: dfsmopars] #1509285
09/28/13 10:20 PM
09/28/13 10:20 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Agreed...MPH number is the true measure of power. I had a bad launch and ran a 2.0 sixty foot time that still netted the same 107 MPH I did with a 1.7 sixty foot time. But my ET was a half second slower.
It might not be in the cards yet, but one day I'd call a quality converter company (PTC, Dynamic) and get one matched to your combo. A good converter isn't cheap, but makes such a difference.
Tuning the carb you already have will help tremendously. (I run a 750 Holley DP on my street/strip car and love it.) That relatively low MPH to me shows a possible fuel delivery issue.
What kind of tires are you running? Drag radials?
Re: Please rate time slip for street car [Re: dfsmopars] #1509286
09/28/13 10:37 PM
09/28/13 10:37 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Car
Time Slip
60'- 2.02
E.T.- 14.20
MPH- 93.5
Hmmmm. If you are a typical hobbyist and just took it to the track the first time, I think that is pretty good. That car/engine combo from the factory was a high 15 second deal. Do you know what the car weighs?
Unless you have done this before, it is hard to put it together, go to the track, and expect it to be near perfect. I would guess that you could get it well into the 13s at 96 mph with tuning, trialing and several more track visits.
Just noticed the tire size. Put a smaller tire on it. That alone will probably put you at 14.0 and 95 mph.
Re: Please rate time slip for street car [Re: BSB67] #1509287
09/28/13 10:45 PM
09/28/13 10:45 PM
RobX4406 Offline
RobX4406  Offline
Takes about 230-240rwhp to move 3900# to those times/mph.
It's missing a BUNCH!
Re: Please rate time slip for street car [Re: RobX4406] #1509288
09/28/13 10:51 PM
09/28/13 10:51 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I disagree. He probably has an honest 290 flywheel hp. I would not really expect more than 320, maybe 330 out of it.
Re: Please rate time slip for street car [Re: dfsmopars] #1509289
09/28/13 10:58 PM
09/28/13 10:58 PM
Kentucky
Kentucky
OK, where to begin. Everyone's replies are very thought provoking.
Car weight- 3600#?
Tires are Toyo Proxes mounted on 18x10s
The TC was picked because I needed a LU for an A500. This is first and foremost a cruiser and long hauler but needs to perform to its potential
Switched out Carter for Eddy 1411 and it was way worse- put the Carter back on
Thought the car ran good, driver could have left the line harder but it wasn't horrible, expected low 14s but hoped for high 13s
A few 1/4 mile passes before with best previous experience was a '01 Firehawk 6 speed that went 13.05 @ 106 mph.
Seeing a common thread in the replies
Re: Please rate time slip for street car [Re: BSB67] #1509290
09/28/13 11:05 PM
09/28/13 11:05 PM
RobX4406 Offline
RobX4406  Offline
That's 360 w/stock heads and xe256-268 hyd territory.
That engine should be making an honest high 3's easily. RHS headed 360's with 9.5:1 and xe275hl will make 420's+.
The tune up, fuel delivery, something is way off, IMO. 3600# only makes it look worse.
Re: Please rate time slip for street car [Re: dfsmopars] #1509291
09/29/13 12:06 AM
09/29/13 12:06 AM
I would try 30 and 32 degrees total timing and see if that helps the MPH, all the SB with iron heads that I have helped tuned like it I have absolutely no experience with the heads your running so if you have treid 30 and 32 and your motors likes 35 please let us know, I'm sure there are more than one other SB Mopar on here are using them
Re: Please rate time slip for street car [Re: Cab_Burge] #1509292
09/29/13 12:42 AM
09/29/13 12:42 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
For what it's worth...
My combo
5.9L magnum.
Stock heads
2bbl M1 intake
222/228 107LSA, .544 lift
4000lb truck
Stick shift 3.92 gears, 27" tires, stick shift
2.2-2.3 60'
14.2 @ 99 mph
Your combo has a slightly smaller cam, but better flowing heads. You have a lot more potential with more tuning.
**Photobucket sucks**
Re: Please rate time slip for street car [Re: 70Cuda383] #1509293
09/29/13 12:44 AM
09/29/13 12:44 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Oh and chassis dyno shows 285 HP and 325 TQ
Re: Please rate time slip for street car [Re: 70Cuda383] #1509294
09/29/13 01:34 AM
09/29/13 01:34 AM
Glendale Az
Darryls-Demon Offline
Glendale Az
Since when does a 72 Charger only weigh 3600 LBS?
Re: Please rate time slip for street car [Re: 70Cuda383] #1509295
09/29/13 01:36 AM
09/29/13 01:36 AM
SE PA
Yellow Fever Offline
SE PA
Not bad.
My 64 valiant vert did 14.5 with a stock 318 4bbl and dual exhaust with a 4 speed. Had a huge vacuum leak though and hard to keep the skinny tires from spinning.
Re: Please rate time slip for street car [Re: Darryls-Demon] #1509296
09/29/13 08:54 AM
09/29/13 08:54 AM
Kentucky
Kentucky
Only a guess based on other cars I have actually weighed in the past. Apparently my guess is off.
FWIW A few weeks ago the car had a short bog or stall at initiall WOT but would bark the big tires in second. Remedy was advance timing a little more, change the pod settings in the dist and eventually the stall went away and so did the tire bark. Bogging is not an option but maybe 32* would be worth a try again. Gotta find a good carb combo it sounds like.
Re: Please rate time slip for street car [Re: dfsmopars] #1509297
09/29/13 09:36 AM
09/29/13 09:36 AM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
converter can be a weak link...need a good one to transfer power...and suspension is whatI'd look at next. Not bad numbers
Re: Please rate time slip for street car [Re: dfsmopars] #1509298
09/29/13 02:05 PM
09/29/13 02:05 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Undo those changes to get your '2nd gear bark' back
Then tune out the bog with the carb pump shot. It's probably a lean slot and needs more gas
Page 1 of 4 1 2 3 4
