69 Dart rim backspacing Questions #1509248
09/28/13 08:36 PM
09/28/13 08:36 PM
Hawaii
Dodgeballs Offline OP
Hawaii
69 dart 340/ 4sp/ 8 3/4 1" drop oval track leafs.
I have some 245/60/14 tires for the back
215/70/14 front
I know 245's will be tight, but they're the tires I have. What rim backspacing should I get - front and back? I'd rather not do the spring relocation. I'd like to try and fit them - relocate springs if necessary afterwards.
Re: 69 Dart rim backspacing Questions [Re: Dodgeballs] #1509249
09/28/13 08:42 PM
09/28/13 08:42 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
245's fit no problem on a Dart.
I have them on my 70 with factory rallye rims.
Re: 69 Dart rim backspacing Questions [Re: RobX4406] #1509250
09/28/13 08:45 PM
09/28/13 08:45 PM
Hawaii
Hawaii
Are those on 15x7 rims or factory 14x5.5?
Re: 69 Dart rim backspacing Questions [Re: Dodgeballs] #1509251
09/28/13 08:54 PM
09/28/13 08:54 PM
Hawaii
Hawaii
Also, What width rims would you recommend for those size tires?
Re: 69 Dart rim backspacing Questions [Re: Dodgeballs] #1509252
09/28/13 09:46 PM
09/28/13 09:46 PM
michigan woods
imfixinmopars426 Offline
michigan woods
on one of my 68 darts I had 275/60-15 15x8 welds with 5.5 b/s. 5" would have been better,but centerlines are about the only ones,unless custom. I moved springs inward,offseting front and rear shackle and hangers...then perches to match...springs against the frame rail in front,cut hole in frame for bolt heads,or nuts.i trimed the wheel openings,and the "GT" mouldings studs,and nuts....looked killer! wish I had pics
Re: 69 Dart rim backspacing Questions [Re: imfixinmopars426] #1509253
09/28/13 11:02 PM
09/28/13 11:02 PM
Mira Loma, CA
69B3GT Offline
69B3GT  Offline
Mira Loma, CA
255s on my dart. Everything in the factory location. 15x7 rim. If I turn a hair too fast it'll rub the lip on the quarter. Nothing a little trimming cant fix.
Rims have same back space as the cop steels. Cant remember if its 4.5 or 4.25
Re: 69 Dart rim backspacing Questions [Re: 69B3GT] #1509254
09/28/13 11:35 PM
09/28/13 11:35 PM
Hawaii
Hawaii
Thanks. I'll have to find some 14" rims. Too much hassle to change the front setup right now.
Re: 69 Dart rim backspacing Questions [Re: imfixinmopars426] #1509255
09/28/13 11:36 PM
09/28/13 11:36 PM
Hawaii
Hawaii
275's on a dart must look tough.
