Re: Highway shimmy/vibration
[Re: mopartruckguy]
#1509193
09/29/13 11:49 PM
09/29/13 11:49 PM
Posts: 3,265 Pyeongtaek, South Korea
69HemiGTX
Slop in the ball joints can allow both caster and camber changes, which can cause a shimmy. I'm not so sure a driveshaft u-joint will cause it, but it's not good regardless. Check to see how tight the rod ends are on the steering linkages and the track bar. An easy way to check is to have someone move the wheel back and forth without turning the tires too much. Any 4x4 Dodge owner knows all too well about the slack-on-center in the steering. Obviously, you need to lie on the ground in front of the truck, and it needs to be running, so do this with someone you trust. Make sure the steering damper isn't weak or blown, too.
OIF V and OEF X veteran and proud of it!
[Re: 69HemiGTX]
#1509194
10/01/13 11:52 AM
10/01/13 11:52 AM
Posts: 5,789 Hamilton, Ontario Canada
Magnum
If the guy at the tire shop is correct. You can diagnois this yourself by supporting the truck by it's rear axle. Thn remove the rear wheels and drums. Run it up to speed and note the vibration.
An out of round tires, bent rim, problem in the sidewall of a tire, tire can still be perfectly balanced.
[Re: 76dodgeboy]
#1509196
10/01/13 10:45 PM
10/01/13 10:45 PM
Posts: 2,034 NW Indiana
deansrr
NW Indiana
1. rotate tires front to back, test drive and see if anything changes, if so change one side and narrow it down to which tire or rim is bad
2. if rotating doesn't change a thing then while driving put in neutral and see if anything changes, if so drivetrain ( if you can take it out of 4 wheel drive do it and see if anything changes )
3. also try touching brakes when shimmy starts and see if anything changes.
you just need to take one step at a time to naeeow it down
good luck!!
1973 Road Runner
1974 Satellite (for sale)
1973 240z (wifes)
1993 Ramcharger (thanks Devil)
2002 Honda S2000
