CNC ported aluminum heads
#1509097
09/28/13 04:57 PM
09/28/13 04:57 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
I have been looking into a few options for CNC ported aluminum heads to offer customers. I have a few questions for you guys to kind of steer me n a direction If you were looking for,say a standard port small block head that had been CNC ported,what would sway you one way or another? If a casting were from a USA based company and flow numbers were the same or similar to an imported casting but the cost was higher,which would you choose??? If I offered USA based castings,but the flow numbers were slightly less than an advertisement showed for somebody else's foreign based casting but cost less which way would you go ? If I offered a similar foreign based casting with some flow numbers that were less than someone else advertised,but were significantly less expensive,would that be your choice ?? Basically,is cost,advertised flow numbers,,or country of origin you main priority? Keep in mind that all flow benches read a little different . And most advertised numbers tend to be generous. Thanks for any real opinions,but please don't just jump on an anti Chinese bandwagon if you have no interest in the main subject here. Keith
Re: CNC ported aluminum heads
[Re: Dunnuck Racing]
#1509098
09/28/13 05:37 PM
09/28/13 05:37 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
Since you are trying to gauge the market, how about listing the current products and target use for each? I guess you shouldn't include names of the heads or vendors to avoid a However, any input for intended RPM, size, and typical use would help define the markets and narrow what people want/need. EXAMPLE: 340-360 max RPM 5500, street (do you even need ported aftermarket heads?) 340-360 max RPM 7000, street/strip 340-360 Strip only Stroker (400-420) max RPM 5500, street Stroker (400-420) max RPM 7000, street/strip Stroker (400-420) Strip only Bigger stroke, more RPM Also lay out what valvetrain requirements are needed for each proposed head, so full cost can be considered. An economical head that requires space program priced cam/lifters/pushrods/rockers/springs is not a bargain.
#1509099
09/28/13 06:01 PM
09/28/13 06:01 PM
Posts: 7,506 Az
Crizila
Az
Just went throughnt his scenario and ended up buying a set of CNC ported Edelbrock magnums from Hughes. Why you ask? Edelbrock is a reputable US company. Hughes is a reputable US company that I have used in the past - and got to deal directly with Dave - what a treat! Probably paid a little more than some others for the comfort level. I was able to use some of my existing Magnum valve train / head studs over again. Their stated flow #'s were with in 10% of the highest and lowest #'s available for this style head. I knew who cast the heads and aluminum used in their castings was a known quantity - not that I am a metallurgist . Options available included inserted LA intake manifold bolt pattern.
Fastest 300
#1509102
09/28/13 06:40 PM
09/28/13 06:40 PM
Posts: 914 tn
robnbird
tn
you could look at the boarded up windows in Detroit for some answers. If we had racers who could afford to race they would prefer American quality... welfare check can't buy very many parts these days.
[Re: RodStRace]
#1509105
09/28/13 10:02 PM
09/28/13 10:02 PM
Dunnuck Racing
Northern Indiana
Basically what I am considering offering will be Edelbrock castings for small and big block both. The problems I am looking into are competitive pricing compared to imported castings with a similar level of work. There are some decent quality imported castings which look to be direct copies of Edelbrock heads as far as appearance goes. The other issues come from several places that advertise flow numbers that are not being seen on any one else's bench. I know of a few. I would plan on listing fairly realistic flow numbers,possibly runner cc's etc. Depending on what people want. I may just buy imported heads and call them my "Quicktree Special" Keith
[Re: Crizila]
#1509106
09/28/13 10:09 PM
09/28/13 10:09 PM
Posts: 462 Stockholm, Sweden
fed
Stockholm, Sweden
Hp /$ That wats counts American made or not.
Cuda, -70 Valiant-65 AWB, Valiant Signet200 -65 Topchopped dragcar. Topolino Fuel Altered. NostalgiaFED Sold, SuperComp Bantam Altered, Sold Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
#1509109
09/28/13 10:25 PM
09/28/13 10:25 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
Keith
And you can include a free pinion angle set-up chart with with each sale.
[Re: 64Post]
#1509110
09/28/13 10:31 PM
09/28/13 10:31 PM
Posts: 6,563 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Keith
Kevin
#1509111
09/28/13 11:14 PM
09/28/13 11:14 PM
Quicktree
Keith
nice
[Re: 64Post]
#1509112
09/28/13 11:15 PM
09/28/13 11:15 PM
Quicktree
Keith
if he did they still wouldn't understand
[Re: Crizila]
#1509114
09/29/13 12:19 AM
09/29/13 12:19 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Modern Muscle does cnc porting of your Gen III hemi heads. They have a deal where you strip your heads, get them cleaned and then send them to them. They will run their program on them for $599.99 and ship them back. That is a good deal in my book for most of us tight a$$ Mopar folks in my book. Then you can have your local guy, or you, do the valve job and assemble.
Mopar to the bone!!!
[Re: Bignick]
#1509116
09/29/13 01:22 AM
09/29/13 01:22 AM
Posts: 3,415 Toronto
mshred
Toronto
For me it is flow/power potential, then cost, with where they are being made last priority...Sure I prefer to buy domestic products over foreign, BUT, if the heads are being bought bare overseas and the CNC work and setting them up is done here, that is enough to assure me the quality is up to snuff.
As for flow numbers, I agree that they should not be the only selling point for heads as is often used....What I really think it missing in the SB mopar world is a set of heads (or more than one set from different manufacturers like the ford and chevy guys have), that is affordable, supports good performance and is not an all out race piece in terms of price and performance.
That said, these new foreign heads that have hit our sb market really seem to be advertised as a great product, but im not sure the performance matches with so little people able to get their hands on them, and then some reporting they don't flow what they should on a bench...really makes you wonder who you can trust.
