A-727 DEEP PAN GASKET? #1509045
09/28/13 03:25 PM
09/28/13 03:25 PM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
I just purchased a like-new B&M deep pan from a friend of mine,and was wondering what pan gasket you guys recommend. I do not want any leaks whatsoever! Someone had told me the new factory steel-reinforced rubber gaskets are a good bet...could I get some suggestions,please? Thanks in advance! Randy B.
Re: A-727 DEEP PAN GASKET? [Re: Labratt] #1509046
09/28/13 03:42 PM
09/28/13 03:42 PM
Tucson, Arizona
MRMOPAR Offline
MRMOPAR  Offline
Tucson, Arizona
That factory pan gasket is the ONLY one I would run. They just plain work and they are reusable.
68 RR 528" INDY MAXX 07 2500 CTD Southwest International Raceway - IHRA - Tucson, AZ
Re: A-727 DEEP PAN GASKET? [Re: MRMOPAR] #1509047
09/28/13 03:47 PM
09/28/13 03:47 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Re: A-727 DEEP PAN GASKET? [Re: MRMOPAR] #1509048
09/28/13 04:04 PM
09/28/13 04:04 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
To be clear - the newer o-ring style gaskets that can be bought today at a dealership are the ones to use.........
Re: A-727 DEEP PAN GASKET? [Re: Labratt] #1509049
09/28/13 04:16 PM
09/28/13 04:16 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
My opinion is the gasket isnt as critical as the pan. I just put a new summit aluminum pan on mine and used the cheapy paper gasket drove it for a couple hrs last nite and its dry as a bone. Your results may vary. Just leave out the rtv. But if its steel, definitely the reusable mopar gasket.
Re: A-727 DEEP PAN GASKET? [Re: MRMOPAR] #1509050
09/28/13 05:47 PM
09/28/13 05:47 PM
Park Forest, IL
slantzilla Offline
Happy Birthday slantzilla  Offline
Park Forest, IL
X a bazillion
Re: A-727 DEEP PAN GASKET? [Re: Hot 340] #1509051
09/28/13 06:36 PM
09/28/13 06:36 PM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
THERE you go ... if the pan-rail is flat ... a cheapO cork should work fine !!
Re: A-727 DEEP PAN GASKET? [Re: dOOc] #1509052
09/28/13 06:51 PM
09/28/13 06:51 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I just used the cheapo cork one with my stock steel pan, because I already had it and the the stores were closed. Used some of the red spray tack, no leaks here...BUT I would have preferred a steel/rubber
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: A-727 DEEP PAN GASKET? [Re: OUTLAWD] #1509053
09/28/13 08:04 PM
09/28/13 08:04 PM
Wichita Kansas
B Dartman Offline
B Dartman  Offline
Wichita Kansas
Have A&A deep steel pan; cork gasket; no leaks.
If pan is chrome, suggest etching the gasket mating surface lightly so the gasket has a surface it can adhere to.
B Dartman's 71 Dart Swinger in Mopar Muscle (Sold Dec 2021): https://www.hotrod.com/articles/1971-dodge-dart-destiny-determination/
B Dartman's 71 Dart Swinger in Dodge Garage (Sold Dec 2021): https://www.dodgegarage.com/news/article/showcase/2019/04/destiny-determination.html
B Dartman's 71 Dart Swinger early build pictures (Sold Dec 2021): https://s165.photobucket.com/user/Billswild440dart/library/
Re: A-727 DEEP PAN GASKET? [Re: B Dartman] #1509054
09/28/13 09:37 PM
09/28/13 09:37 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Chrysler part# 2464324AC. It's a re-useable gasket.
Re: A-727 DEEP PAN GASKET? [Re: rt66jim] #1509055
09/28/13 09:48 PM
09/28/13 09:48 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
exactly wont leak and can be used again and again and again
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: A-727 DEEP PAN GASKET? [Re: dusturbd340W5] #1509056
09/28/13 10:47 PM
09/28/13 10:47 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
My experience has been this.....
CAST aluminum pan : you can use the 2464324AC re-usable gasket.
ANY steel stamped pan: use the cork/rubber impregnated gasket if the pan rails are straight..
I know some of you guys will cry BS, but I've had a FEW leakers and I'll stick to what I say. Nothing worse than a leaky pan after the blanket's on there...makes a messy scene.
Re: A-727 DEEP PAN GASKET? [Re: superwrench] #1509057
09/29/13 12:29 AM
09/29/13 12:29 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
my 01 CTD, our 70 Duster, and our old Mirada all ran the same deep stock steel truck pan (47RE), and the stamped factory gasket. Have had the pans off/on numerous times. torque to 125"lb and no probs ever.
Re: A-727 DEEP PAN GASKET? [Re: J_BODY] #1509058
09/29/13 01:18 AM
09/29/13 01:18 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I had never heard of the factory steel shim gasket til recently so I put one on my Duster with a deep steel pan. I used to always use good cast aluminum pans so the paper gaskets were fine.
Re: A-727 DEEP PAN GASKET? [Re: ProSport] #1509059
09/29/13 11:21 AM
09/29/13 11:21 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks everyone!...looks like I'll be using the factory stamped steel/rubber gasket.
