another MC question #1509041
09/28/13 03:24 PM
09/28/13 03:24 PM
Streetsboro,Ohio
70dart318 Offline OP
Streetsboro,Ohio
Still trying to debug my 70 Darts brakes - for a recap KH disc from a 69 Cuda on the front, rear 10" drum. The master cyllinder I keep getting form the part stores is the same as for drum, same size reservoirs front and back. What would happen if I put on the 73 MC with larger front reservoir? Would it work, could I "blow out" a line or calliper?
Re: another MC question [Re: 70dart318] #1509042
09/28/13 04:45 PM
09/28/13 04:45 PM
It'd work. If manual brakes just confirm the circular recess is there in the rear piston "thimble" about halfway down. Too big of bore might make leg effort objectionable (less leverage) but I have a big bore (1&1/8") alum M/C on a 69 dart with KH sbp discs/10" drums & it stops excellent & you'll be fine
Re: another MC question [Re: RapidRobert] #1509043
09/29/13 12:22 PM
09/29/13 12:22 PM
Streetsboro,Ohio
Streetsboro,Ohio
Thanks RR, I thought it wuld work, just wanted to be sure
Re: another MC question [Re: 70dart318] #1509044
09/29/13 12:29 PM
09/29/13 12:29 PM
You're welcome/much appreciated & good luck with your project
