Re: 11 second 1970 cuda with good street manners?
[Re: Mr.Yuck]
#1508874
11/02/13 04:55 PM
11/02/13 04:55 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
A small block would really be easier in the corners, and lighter in the front. Stroke it! I'm running a 340 stroked to a 416 (also 360's are easy to find (360 + 4.0 crank + 30 over bore = 408 cubes)). She'll run in the 11.teens all day (on pump gas!). With a four speed auto trans, and a lockup converter, that's still obtainable. You can cruse the high way easily too. I'm running a 8 3/4 rear end (never had a problem). I'm sure people out there have better suggestions for you, but keep your options open till you decide. Good luck!
for a 416 SB to run mid 11's in a heavy e-body it'd need a TON of work. I do agree that an 8.75 is fine for mid 11's in an A,B or E body. Mines holding up fine. If you are worried about breaking it just back brace it. That said nothing wrong w/ a 9" either.
If he has the coin...a smallblock Mopar is going to take some serious coin to get it up to the 700 HP ball park ($15-$20K), then reliability/longevity become factors, the stock small block Mopar comes in at 550 lbs, a 383/400 at 620 lbs, and an RB at 670 lbs, not even a concideration...an all aluminum 6.1 Mopar Gen III comes in at 490 lbs and has a base 535HP, an lS1 (427) all aluminum comes in at 450 lbs, or an iron block LS1 at 525 lbs, the all aluminum LS1 is reliable up to 900 HP max, and the iron block LS1 up to 1500 HP reliable...if you look at an engine, as just that, an engine...then the LS1 is the logical choice HP/cost wise like it or not.. IMHO the LS1 mated to a Viper spec'd T56 6spd, and a Ford 9" or Cobra IRS would yield a nicely rounded package for street/strip/course, think of them merely as mechanical components, chosen for performance/cost rather than silly brand loyalty based components which will take more $$$$ to be on an equal basis performance wise.
Crate motors
Gen III Mopar Hemi 6.1 All aluminum 490 lbs 535 HP base $14K 565 HP base $15K 615 HP base $18K
LS1 all aluminum Gen III 450 lbs Iron block/aluminum head 525 lbs 427 cubes 540 HP base $9K 670HP base $10.5K 690 HP base $12K 900HP base $15K
LS1? really why not sell the cuda and get a Camaro then? He can build a 600hp 440 for way under 9k and he won't have to buy any aftermarket crap or be embarrassed to open the hood.
but you have a Chevrolet hood scoop on your car, whats the difference...... ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
[Re: Mr.Yuck]
#1508875
11/02/13 06:14 PM
11/02/13 06:14 PM
"gen 3 hemi swap with a kenne bell blower and tremec 6 speed" not cheap is an understatment. I'm guessing the blower alone is like 6k. He could build a 10 second BB for that alone.
It doesnt have to have a blower at all, I just know that if I built a car that way, I would want one. Yes, it would be pricey with that blower. Yes, a BB would be cheaper and nothing wrong with doing it that way, but he did say he wanted some decent type of fuel economy. Ain't gonna happen with a carb'd 900 lb BB.
[Re: ]
#1508876
11/02/13 06:20 PM
11/02/13 06:20 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
6-pack and a 4 speed and right gear will get him well over 15mpg (probably 20 w/ the new OD 833) I get about 15 hwy at 60mph and that's with 3.91's and an auto.
"but you have a Chevrolet hood scoop on your car, whats the difference......"
because I still have a mopar engine and I needed the clearance, IMO there's no GOOD hood scoop for a 68-70 Charger, so I went with what flowed best w/ the body lines. Gonna jam up a 'cuda guy for a shaker? I mean Furd had them 1st.
[Re: autoxcuda]
#1508879
11/02/13 09:51 PM
11/02/13 09:51 PM
Posts: 3,267 Connecticut
1972CudaV21
Connecticut
IMHO, the most cost effective way to get high HP with good street matter is with CUBIC INCHES.
Start thinking 400" plus small blocks and 470" plus big blocks.
Pretty cost effective as well!
[Re: DAYCLONA]
#1508880
11/02/13 10:57 PM
11/02/13 10:57 PM
Posts: 3,456 Fly Over States
PHJ426
Fly Over States
If you have the coin, then a supercharged Gen 3 and a T56 6spd and Ford 9 inch rear would make for a nice combo...if you want, and HP is your only concern, with no regard to brand loyality, then an LS1, T56 6spd, Ford 9 inch rear or IRS...If corner carving is in the cards
Mike has a valid point. If your going to be utilizing a new generation fuel injected engine you can't really beat the aftermarket support the LS or Coyote engines get with wiring harnesses efi engine controls needed to install these engines into a chassis that was not originally designed for these engines. I did see a mega squirt harness and computer for the 6.1 Hemi engine but nothing from Mopar to my knowledge.
The idea of taking a third gen Hemi and running an old school carb and distributor on it eludes me but hey I'm only one person and maybe the rest of the world is into carbs and dizzy's on new engines?
The Coyote engine is also a good value and takes some weight off the nose of these cars. They need a retrofit serpentine belt kit to run a power steering belt as Ford is now using electric for the power assist on the rack in the new cars. I think its offered by Vintage Air and a few others.
Think of this a Coyote Engine inside a Road Runner..............that would take an easy 250# off the nose of a Mopar powered by a RB Six Pack.
Back on topic my 508 Six pack, 4.25" stroked with 727 9.5" convertor and 2.94 gears and 26" tall tires was knocking out 18+ mpg cruising the highway. Even with 2.94's the car screams that convertor works in that heavy car and slip is less than 2% at 55 mph.
[Re: ahy]
#1508882
11/04/13 02:20 PM
11/04/13 02:20 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
If you want t ohave it all for the least - a typical 505" Rb with a FAST EFI and some sort of modern trans would be chaepest. It won't get the milage of a Gen III but it will look "right" and if it couldn't get high teens mileage wise I'd be surprised. The new hemis are cool but they take a lot to get in place - and nothing's cheap stuff. I'd rather have a car that's worth more than I just put into when I'm done, and a high hp gen 3 swap will be close to break even at best. The last pull out 6.1 I had any interaction in was $6500 byt itself and makes 345hp to the tire with a carb and cam swap. That's not enough steam to put a heavy E body (saddled with options and stuff) to mid 11s. Especially not with the driver shifting it and street rubber.
[Re: RobX4406]
#1508884
11/04/13 07:52 PM
11/04/13 07:52 PM
Posts: 305 5th and plum
redmist
5th and plum
Just over $2000 to convert my 440 to full sequential fuel, and spark using Megasquirt, and the junkyard. I love it.... I just put 60lb/hr injectors out of a 2013 Ford GT500 in it, that I found on rockauto for only $24 a piece! Engine makes 513/542 on the carb, I have yet to dyno it in the car with the EFI. It's MUCH more powerful now than it was with the carb! And it starts with the twist of a key. ![](https://lh6.googleusercontent.com/-kDIGgQ0M2j0/UbVRr5ShNiI/AAAAAAAAATI/AGDnFbNXYco/w1280-h853-no/IMG_2838.JPG)
[Re: redmist]
#1508886
11/04/13 09:43 PM
11/04/13 09:43 PM
Mr.Yuck
Brookeville, Md
I love it....
then your carb wasn't tuned right. Nice set-up I'll say.
[Re: Mr.Yuck]
#1508887
11/05/13 02:30 AM
11/05/13 02:30 AM
redmist
5th and plum
Correct, the carb was never tuned right, because the weather, and altitude changes in life... I don't worry about the simple stuff like how our environment changes, I have modern stuff that does it for me. ![](/ubbthreads/images/graemlins/thumbs.gif) Carbs are great on race motors, but for a car that gets driven a lot, it's a losing battle, or a constant compromise. I have seen the light. Never again will a carb function on a vehicle I own. It's not worth the headache. There is nothing a carb can do better than my EFI setup, except percolate fuel. ![](/ubbthreads/images/graemlins/biggrin.gif) Also keep in mind, that I can control timing now in a linear curve in any RPM, and any load range. That alone is a power builder.
[Re: redmist]
#1508888
11/05/13 09:18 AM
11/05/13 09:18 AM
Mr.Yuck
Brookeville, Md
now all you need is a little boost.
[Re: derekeh]
#1508891
11/06/13 09:58 AM
11/06/13 09:58 AM
Mr.Yuck
Brookeville, Md
Honestly I'm more interested in a small block or gen 3 hemi.... Although that efi big block looks sweet! So its down to a small block or 5.7/6.1 that is fuel injected and most likely supercharged.
it would be hard to get a N/A sb into the 11's in an e-body...w/o some expensive parts. So boost would be t he way to go. If you have any fab skills you can buy a SBC or SBF s/c kit and modify it. Or you can open your wallet and pay out the ash for a pre-made mopar kit.
