5 on 4" bolt pattern rims #1508698
09/27/13 10:36 PM
09/27/13 10:36 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Anyone have a set of front ones, not using that I can borrow ..
I need to set ride height on a project and need a set for that
I'm going to swap to large bolt pattern down the road a bit
Re: 5 on 4" bolt pattern rims [Re: bigdad] #1508699
09/27/13 11:58 PM
09/27/13 11:58 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I have a set of lime green 4" bolt pattern wheels in the wheels\tires for sale section of Moparts but I don't live anywhere near you.
Re: 5 on 4" bolt pattern rims [Re: ProSport] #1508700
09/28/13 12:08 AM
09/28/13 12:08 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
I'll see if I can locate ad
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: 5 on 4" bolt pattern rims [Re: bigdad] #1508701
09/28/13 12:10 AM
09/28/13 12:10 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Bummer
Need 15's
Re: 5 on 4" bolt pattern rims [Re: bigdad] #1508702
09/28/13 02:42 AM
09/28/13 02:42 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
15's are aftermarket only and not easy to find. I have had several sets made mostly 8 or 10 inch wide. I do have a set of Centerline and aluminum slot frontrunners 4" wide laying around. Let me know if you need to use them as they are not for sale.
JB Rhinehart, Realist
A-Body's RULE!
Re: 5 on 4" bolt pattern rims [Re: Rhinodart] #1508703
09/28/13 09:12 AM
09/28/13 09:12 AM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Re: 5 on 4" bolt pattern rims [Re: pinkduster] #1508704
09/28/13 10:48 AM
09/28/13 10:48 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
New set of Centerlines in the 4 bolt pattern are $450
I plan to swap it to 4.5 down the road
( don't want to buy wheels until project is done )
Or at least rolling ..
The car is up on frame table and we are going to set ride height
I can take the front apart and mock up the front then return the wheels
It maybe easier to just buy the front end stuff now
I may just do that ..
Re: 5 on 4" bolt pattern rims [Re: bigdad] #1508705
09/28/13 10:55 AM
09/28/13 10:55 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Don't forget most 4.5 disc brake kits move the front wheels out .5" or more.
Re: 5 on 4" bolt pattern rims [Re: moparpollack] #1508706
09/28/13 11:06 AM
09/28/13 11:06 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Oh yea
I know that
actually, I'm putting a alerkation under it
Wanted to hold off on that until the project hits that spot
but, I might just have to step up now
If I can find some used 4" centerlines I could mock it up and buy the front when needed
Only been waiting to get on table for 13 months this time
3 shop ..
Re: 5 on 4" bolt pattern rims [Re: Rhinodart] #1508707
09/29/13 01:41 AM
09/29/13 01:41 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Where did those come from ???
Re: 5 on 4" bolt pattern rims [Re: JohnRR] #1508708
09/29/13 07:27 AM
09/29/13 07:27 AM
michigan woods
imfixinmopars426 Offline
michigan woods
could you re-drill a set of 15x5.5-4.5 pattern wheels just for static use?
Re: 5 on 4" bolt pattern rims [Re: imfixinmopars426] #1508709
09/29/13 10:51 AM
09/29/13 10:51 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Suppose you could ?
already thought about
welding the 4 inch stock center into a 15 inch hoop
might can do that too
Re: 5 on 4" bolt pattern rims [Re: bigdad] #1508710
09/29/13 01:15 PM
09/29/13 01:15 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
there is a guy in Pa. that does this so it should be easy.
