Replacing pinion yoke #150836
11/14/08 12:57 PM
11/14/08 12:57 PM
Virginia Beach, Va
wtucker Offline OP
wtucker  Offline OP
Virginia Beach, Va
Is it hard to replace the pinion yoke on an 8 3/4? Is it as simple as removing the nut and pulling it off, and putting the new one back on? Or is there some special process to do it?
Re: Replacing pinion yoke [Re: wtucker] #150837
11/14/08 01:10 PM
11/14/08 01:10 PM
pretty much yes if it's a 742/741. You have to anchor the yoke to R&R the nut & takes the right puller to draw the yoke off. A 489 with the crush sleeve needs the pinion to be dissassembled and the crush sleeve replaced or a solid sleeve added which is a better setup anyhow.
